Where to find a cup stone for my 9 inch grinder
发表于 2021-8-31 23:54:44 | 显示全部楼层 |阅读模式
Hello i am trying to find a cup stone for my grinder. so i can use it to clean my weld table. i found out this idea by another thread on here.I thinks it called how to clean spatter of a weld table and I'm interested in this different type of grinding method. ThanksMillermatic 211 with mvp plugs miller titanium series welding helmetstihl chain saws 8 ft welding table
Reply:Check your local welding supply they should have. I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:I don't know how much spatter you have on your table, but I never use a hard grindstone for that purpose. I use a 40 - 60 grit sanding disc or type 27 (flat) flap wheel. Less chance of gouging the table and ending up with a wavy surface.JohnA few weldersA lot of hammersA whole lot of C-clamps
GMT+8, 2025-12-24 10:14 , Processed in 0.166736 second(s), 18 queries .
