Hey guys.Any suggestions for practice root passes on pipe with 6010,6011, and 7018. Im thinking about using some 1/8" wall tubing to practice on, maybe 2" tubing. I want to try and keep material cost down. Any thoughts on this ?The first pic is with Lincoln 6010 5p+ ran with a powerarc 200. The second is with 6011 ran with a 1970's Miller Dialarc 250. Im used to running 6011 its kind of the way most roots are put in in the province unless they are put in with 7018 or Tig, I just want to be able to run 6010 too..... Attached ImagesJourneyman / Red Seal Welder (What a useless test)Miller CST 280Miller XMT 350Miller 12vs XtremeEvolution Evo 28 mag drillEvolution 380 Dry Cut saw
Reply:little heavy for a boiler bead pass. you'd pass all day long tho where i work, if its clean.
Reply:I would forget about using 6011 for your pipe roots. 6010 is the code rod for pressure pipe work. Not many places want you to use 7018 for pipe roots.I would stick with your Miller dial arc and 6010 5P+ for your pipe root and hot pass. Then use 7018 for your fill and cap.Your roots look well. Maybe a wee bit much of reinformencent on the inside but thats easily workable. Your root looks fairly even all the way around. You are on the right track for sure.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:6011 is the procedure where I work no choice in the matter. 6010 is rarely used around here. Both of these roots have under 1/8 reinforcement inside, I checked, its kind of hard to tell in the pics though.Id like to get good with 6010 though just incase I end up out west. I find 6011 easier to run but thats due to learning to root pass with it in school. I dont have access to the dialarc anymore for practice, the little green machine welds better anyways, which is a big suprize, who knows how long it'll last though....ThanksLast edited by Newfie_1986; 04-05-2012 at 10:50 PM.Journeyman / Red Seal Welder (What a useless test)Miller CST 280Miller XMT 350Miller 12vs XtremeEvolution Evo 28 mag drillEvolution 380 Dry Cut saw |
