Payback for tig torches
发表于 2021-8-31 23:54:32 | 显示全部楼层 |阅读模式
I finally did the payback for the tig torches, full "T" ar cyl, and two stage reg.My buddies boat trailer's center support tube was loose  I used my old Lincwelder 180 because I had to fix it in the factory where he stores it. Welder was idling fine but when I struck an arc the rpm's would fluctuate. It made it difficult because on this unit you set the amps by the rpm. All welds were McKay 7018XLM 1/8" & 3/32"."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:"Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:Drill a hole in that tube so it drains. I see this all the time and one small .25" hole would slow the rust down a lotIf you cannot convince them, confuse them.         Harry S Truman
Reply:nice work are those Formula Fastech boatsthere the best Attached Images
Reply:Originally Posted by 500HpSilveradoDrill a hole in that tube so it drains. I see this all the time and one small .25" hole would slow the rust down a lot
Reply:Originally Posted by ed macnice work are those Formula Fastech boatsthere the best
Reply:And my perspective new customers."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:Very nice work. I have fixed a few where the owner slammed on the brakes while towing and they broke from the rust thru from the inside, they did not have a clue it was bad.I love Fountain boats just can not afford one or the fuel to run it$$$$$$$$$$ so my old Cobalt will have to do.Miller 330 A/BP Bernard SS coolerMiller cst 250Miller Big Blue 251DCentury 210 Mig (first welder I bought)Hypertherm PowerMax 800Victor torch setRu Fong 31 MilAtlas lathe
Reply:Tell those cheapos to get an aluminum trailer. well maybe not then you lose all the work. But anyway, the aluminum ones hold up  a lot better, and they are shiny!If you cannot convince them, confuse them.         Harry S Truman
GMT+8, 2025-12-24 10:14 , Processed in 0.104082 second(s), 18 queries .
