welding tanks
发表于 2021-8-31 23:54:26 | 显示全部楼层 |阅读模式
Going to buy some tanks today. My? is there any way to tell the difference between a rental tank verses a owner tank?Thanks
Reply:Customer-owned bottles don't (normally) have a gas vender name imprinted in the ring at the top of the bottle. Sometimes they do, but if they do, it's tough to tell they're not stolen. If the seller can give you a bill of sale from where he got them, that might help when you go to get them filled.I'd be careful. I bought some bottles and then couldn't find anyone to fill them for me.
Reply:Usually the ones for sale are not the large ones like the K or T size. Usually, you don't have a problem getting the small to medium size filled. I would try to find a mom & pop gas supplier, they are usually easier to deal with as far as the large cylinders."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:my lws will exchange anything i take into him. he did refuse one out of 8 bottles i picked up for dirt cheap on cl. honestly guys and gals i hadn't noticed the problem with that one since i wasn't the person that loaded it in my truck. i picked them up and went straight to my supplier to exchange them. it appeared that some one needed the bottom of that gas bottle more than the bottle did. i must say i wish i had that dudes band saw because my old Kalamazoo don't cut that true but it cut the top square enough to make a nice bench grinder stand.225NT bobcatAEAD200LEScott 125mm175, mm252 w 30A, PT225mm211, TA 181iHyper Therm 380, cut master 529100X & XX, Digital Elite6 Victor setssmith little torch, meco midget kalamazoo band sawsteel max saw evoulution circular saw
Reply:Going to met the guy in the morning.says he has a  75/25/mix tank  size 160and a argon tank size 160both tanks are full$200.
Reply:both for 200? nice price if no names. oh and take your reg and gauges. still a decent price if empty.225NT bobcatAEAD200LEScott 125mm175, mm252 w 30A, PT225mm211, TA 181iHyper Therm 380, cut master 529100X & XX, Digital Elite6 Victor setssmith little torch, meco midget kalamazoo band sawsteel max saw evoulution circular saw
Reply:I bought a 120 cu ft mig mix tank from the lws (Scott Gross, a regional outfit).   After I got it home I noticed their name on the collar.  The bill of sale clearly says "purchased".   Am I right to feel they pulled a fast one on me?Ken
Reply:Originally Posted by k45I bought a 120 cu ft mig mix tank from the lws (Scott Gross, a regional outfit).   After I got it home I noticed their name on the collar.  The bill of sale clearly says "purchased".   Am I right to feel they pulled a fast one on me?Ken
Reply:DSW,Thanks for clarifying the issue.Would this restrict my looking for cheaper refill alternatives locally though?  (Although I suspect this place is probably fairly priced.)Ken
Reply:Originally Posted by k45DSW,Thanks for clarifying the issue.Would this restrict my looking for cheaper refill alternatives locally though?  (Although I suspect this place is probably fairly priced.)Ken
Reply:What is a "welding tank" Is this a new process where you dip the parts in the tank and they come out welded?
Reply:Well just picked up the 2 tanks.both were full.Hey Fat Bastard I think you know what I mean.
GMT+8, 2025-12-24 10:22 , Processed in 0.040512 second(s), 17 queries .
