查看: 2|回复: 0
Can a mig sheilding gas tank be used horizontally?
发表于 2021-8-31 23:54:20 | 显示全部楼层 |阅读模式
The title pretty much says it all. In my specific case I'm trying to get my mm175 mobile and it would all be a lot easier if I could lay the tank flat in my truck. I'll be using 72/25 mix. I remember at some point seeing a horizontal tank holder, so I assume its possible. Any special considerations? Any problems using the standard regulator?
Reply:Sure.  The gas in the tank of compressed gas doesn't care.But watch out for some DOT-types.  They freak and/or write tickets for a compressed gas tank that isn't vertical.  And -some- possible 'interpretations' of OSHA regulations are that tanks have to be vertical AND have the safety caps over the valves whenever a tank is transported or 'not in use'.  The best laid schemes ... Gang oft agley ...
Reply:Tanks are meant to be vertical. Get a little baby tank if you need too. --Gol'
Reply:I do it all the time, everything except for my MAPP and C02(both containe liquid) are laying down.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Anything with CO2 needs a bit of slope to it, I've run CO2 bottles with just a 4X4 under the valve end just fine.Simple compressed gasses don't care if they are upside down or whatever. People who tell you otherwise don't know what they be talkin bout.JTMcC.
Reply:Originally Posted by Go1lumTanks are meant to be vertical. Get a little baby tank if you need too.
Reply:just dont shield with acetylene
Reply:Originally Posted by JTMcCThat's just plain missinformation dude.Compressed gas comes out of the cylider the same regardless of orientation. That's why fighter pilots don't die when they go inverted, the oxy flows to the drivers mask just as if it was oriented in a vertical state.Cylinders with a liquid inside need some upwardness to the upward end, but not a lot.JTMcC
Reply:Originally Posted by Go1lumI never see supply trucks unloading bottles from the horizantal position. I wonder why.
Reply:Originally Posted by JTMcCAnything with CO2 needs a bit of slope to it, I've run CO2 bottles with just a 4X4 under the valve end just fine.Simple compressed gasses don't care if they are upside down or whatever. People who tell you otherwise don't know what they be talkin bout.JTMcC.
Reply:Originally Posted by Mega Arc 5040DDThis is true except for acetylene. Acetylene bottles can be transported laying down but must be vertical one hour before use and when in use to avoid the release of acetone wich can damage your regulator.
Reply:Bravo, this is good information.....BrentLincoln 3200HD MIGLincoln AC/DC 225 Stick
Reply:Originally Posted by JTMcCYou could of asked the manager at your welding supply, and saved yourself a lot of trouble. Then you would no longer have to "wonder why".Life is like that, we have questions, and innevitably there are people out there with the answers. No need to make it up. Search out those people and ask them.And the problem with the internet is that you can make things up down at the gas station, but on the net you'll likely run into someone who actually knows, or knows someone who knows someone who knows.JTMcC.
Reply:Originally Posted by JTMcCThis is true, period.Acytelene isn't a simple compressed shielding gas. You are sidetracking a conversation about "shielding gas" into a discussion of acytelene. And your fact's on acytelene are wrong as well. Acy can, and osha has made exception for its use in low clearance applications, at 30 degree from horizontal. Can you people please try to post accurate info???JTMcC.
Reply:Originally Posted by Go1lumSo your saying i shouldn't be on this board offering welding knowlege. Im gonna laugh when you have a vavle get sheared off when your tank is laying sideways and it pushed your rig 1/4 mile down the road or goes right through it. . I never said it couldn't be done. I'm saying they are meant to be stood up it's safer.
Reply:Originally Posted by Mega Arc 5040DDII just didn't want anybody to think what you said actualy applied to all compressed gasses when in fact it does not. But I thank you for the rest of your info because I to was wondering if I could put my mig bottle on its side in my rig to save space and now I know.
Reply:Here's the problem with the internet, you may get away with being an expert on every topic down at the local gas station or donut shop, but when you venture out into cyberspace, and it doesn't matter wether you post on nuclear physics, quantum theory, growing roses or welding.....there is going to be some dude show up who works in that field, and actually knows how it's done. This is good because it weeds out the wannabes's who pretend to understand fields they really have no experience in. But it's bad because every hack with just enough knowledge to be dangerous gets to hold forth like they really know what they're talking about. And some people will believe the crap they spew forth. So it's a double edged sword. Buyer beware.JTMcC.
Reply:strip mine near by makes all of their repair guys put these big mailbox size cages around their regulators. even if the bottles are secured in racks.  screws onto the top and covers the valve and regulators.
Reply:I think it's time for some singing and a big group hug.  Proud to be self-employed and not have to rely on ANYONE but me to make my way in this world.Dynasty 350DXDynasty 200DX MM 350PMM 210MM Passport PlusSpectrum 375 Extreme08' Trailblazer 302
Reply:Originally Posted by JTMcCYou are a total idiot. When I had oxy bottles oriented horizontal on my rig (many years ago) there was no way a force capable of "shearing off a valve" could come in contact with the valves. Do you assume everyone is as stupid as you????And you're "gonna laugh"? what a stupid jerk you are. Have you seen the top end of a cylinder knocked off? I have, nobody laughed as the helicopter flew away with the injured workers. You are a stupid idiot. And you "laugh"???? If you think an oxy cylinder will propel a 12,000 lbs truck a quarter mile "down the road" you didn't pay attention in H.S. physics.I'll repeat in case I wasn't clear, you are a stupid idiot and you have no business posting information on a welding site.JTMcC.
Reply:ANSI Z49.1 8,6.6 Cylinders shall be locked or secured so they cannot be knocked over.10.8.4.12 Secure Cylinders during use. A suitable cylinder truck, chain, or steadying device shall be used to keep cylinders from being knocked over while in use.Find me something that says it's ok for any cylinder to be used in the horizontal position. Besides your arrogant opinion.Last edited by Go1lum; 11-22-2008 at 01:06 AM. --Gol'
Reply:Originally Posted by Go1lumANSI Z49.1 8,6.6 Cylinders shall be locked or secured so they cannot be knocked over.10.8.4.12 Secure Cylinders during use. A suitable cylinder truck, chain, or steadying device shall be used to keep cylinders from being knocked over while in use.Find me something that says it's ok for any cylinder to be used in the horizontal position. Besides your arrogant opinion.
Reply:Originally Posted by JTMcCDude you are as incompetent as they come on the internet, you need to get your butt off the computer and get out in the world and learn how things work.Trust me, you don't have a clue, stop giving bad advise that people might actually believe.JTMcC.OK folks, enoughThread lockedDavidReal world weldin.  When I grow up I want to be a tig weldor.
GMT+8, 2025-12-24 10:57 , Processed in 0.196777 second(s), 18 queries .
