Well, I joined --
发表于 2021-8-31 23:54:13 | 显示全部楼层 |阅读模式
the hitch receiver vise mount club. Picked up the receiver at a yard sale for ten bucks and already had a short piece of 2 1/2" seamless, so thought I'd get my big vise up where it can used readily. It's not a real heavy duty vise, but w/ my table on casters I don't figger I'll be reefin' real hard on it!!                                           MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:Cool!MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:You must be really short.  Looking good, don't forget the weld nut.  You know, drill a 9/16" hole underneath, weld a 1/2-20 nut over the hole, run a 1/2" X 1" bolt through onto the vise mount to take up the backlash.  It makes for a sturdy vise. Attached ImagesCity of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:I hear there are support groups for your affliction Attached Images"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Looks good Mike.  Well welcome to the club!Others on the way.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Dam! Now I have to get my but in gear and join . When I first seen  that great receiver mount idea here ,I new I had to make one. But I am pissed I didn't see the wide uses for it. Both my vices and my bench grinder don't have a permanent home.I will have to make a couple so I can have the benchtop vice, short guy vice and the bench grinder.   Another one of those  "why didn't I think of that" tools.
Reply:That's called a Gary Coleman Vise MountEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Originally Posted by Broccoli1That's called a Gary Coleman Vise Mount
Reply:Now, Broc, I've got a fresh batch of roundup to take care of you. I take the ribbin' and jokes OK. I just figured it was best to keep it there instead of over in the corner where it's been for two yrs.  Once I've banged my shins on it a couple of times I'll learn to give it a little more room when walking by it!!!                                     MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
GMT+8, 2025-12-24 10:57 , Processed in 0.089441 second(s), 18 queries .
