3-1/2 HP 14" Industrial Cut-Off SawItem #68104 4.6(9)Read 9 ReviewsWrite a ReviewOnly:$149.99Sale: $99.99 ok this is the one i was looking at . I will maby use this thing 2 or 3 times a year. also if i do buy it can i put a carbide blade on it we have one on the saw at work it has ben on there for years and it cuts black pipe quite often. thanks for the advise jerry
Reply:no carbide blade on that saw rpms are too highMiller Xmt 350Lincoln Ln-25Ahp 200xSmith Gas Mixer AR/HTig is my Kung FuThrowing down dimes and weaving aboutInstagram http://instagram.com/[email protected]
Reply:You cant put a carbide blade on a normal chop saw, you will tear the teeth off it and probably get yourself hurt. The carbide blade saws only spin around 1300rpm's
Reply:Yep always be sure to match the blade rpm with the rpm of the saw or your asking for trouble.I have that saw and it's loud and the clamp broke. It doesn' stay tight, the threads got slightly chewed up after some mild use. And to be honest it makes a mess like any chop saw and I haven't had a need for it since getting the horizontal/vertical band saw.Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer |
