Plasma Cutter from Cyberweld
发表于 2021-8-31 23:54:06 | 显示全部楼层 |阅读模式
Folks,I'm currently in a position to get more tools, and one of the items on my "want/need to buy" list is a plasma cutter.Lanse loves his Powermax 45 by Hypertherm but I think it might be a tad high on the $ side.....I'm now looking at something a bit smaller by Thermal Dynamics (I think they invented the Plasma Cutter).......Has anyone ever purchased from Cyberweld? They are showing free shipping, and of course no tax since they don't have a location in Texas......Thoughts on this site? On the machine?http://store.cyberweld.com/thdycu42p...753432706c6375Precision TIG 185 and MP 210Bobcat 225NTCutmaster 42O/A tanks.... 2 Argon tanks...... 2 C25 TanksFacebook...... F2 Metal WorksETSY....... https://www.etsy.com/shop/F2MetalWorksF2MetalWorks.com....... http://www.f2metalworks.com/
Reply:I bought my welding helmet from them and had no issues. I have no input on the plasma though.Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:you should have free shipping about anywhere you purchase from, as the unit will more than likely be drop shipped.. You might look at Indiana Oxygen, I ordered 2 welders from them years ago and they had great service and speedy shipping, I received both welders within 2 days of ordering..  I've heard others on here order from cyberweld and have no problems..  The cutmaster 42 seems to be a popular model..indiana oxygen http://www.weldingsuppliesfromioc.co...STER-42/Detailscott gross is another popular web store http://www.scottgrossstore.com/servl...ster-42/DetailLast edited by brucer; 04-09-2012 at 11:18 PM.tackleexperts.comwww.necessityjigs.comhttps://www.facebook.com/groups/mach...dingequipment/
Reply:I bought my Cutmaster 102 from them a few years ago. No issues.
Reply:Great..... Thanks...Precision TIG 185 and MP 210Bobcat 225NTCutmaster 42O/A tanks.... 2 Argon tanks...... 2 C25 TanksFacebook...... F2 Metal WorksETSY....... https://www.etsy.com/shop/F2MetalWorksF2MetalWorks.com....... http://www.f2metalworks.com/
Reply:But then again....for a few bucks more to buy, and a lot less bucks (longer consumable life) to use.....and it is made in Hanover NH, USA.  Cuts from a Powermax using the 45 amp shielded process. (Powermax45, 65 or 85).Jim.080" aluminum, 1/4" steel, 3.16" aluminum, 3/16" stainless, 1/2" steel. Attached Images
Reply:I really like the Powermax45, but if it is more then yo want to spend then check out Indiana oxygen They have a Special offer on the Cutmaster42 for $942.87 with free shipping.www.georgesplasmacuttershop.comPlasma Cutter and Welder Sales and Repairs--Ebay storeTec.Mo. Dealer Consumables for the PT and IPT torch's
Reply:I've purchased a lot from Cyberweld and they are honest and ship fast. A first class vendor.
Reply:I bought a Hypertherm Powermax 30 from Weldingmart a few months ago...   $1025 out the door....great machine  .....USA made
Reply:Originally Posted by jimcoltBut then again....for a few bucks more to buy, and a lot less bucks (longer consumable life) to use.....and it is made in Hanover NH, USA.  Cuts from a Powermax using the 45 amp shielded process. (Powermax45, 65 or 85).Jim.080" aluminum, 1/4" steel, 3.16" aluminum, 3/16" stainless, 1/2" steel.
Reply:No problems from cyberweld.  I've bought a few big $$$ items from them and tons of little stuff.  No problems on any of it.  I even had them call me one time to double check there wasn't a screwup (and there wasn't).I'm not sure what stuff you work on, but I wouldn't buy a plasma with a max cut of 5/8".  Even if it means waiting and saving your nickles, I think you'll be happier in the long run with something a little bigger.  If you have a bigger one that has fine cut consumables you get the best of both worlds.  Big current, big consumables for the thick material.  Turn down the current and use fine consumables to get a small kerf and clean cut on thin material.Do you already have an O/A setup?  For hand cutting a good O/A setup will do just as nice of work as the plasma.  I have O/A on the truck since I don't have an air compressor or enough generator on the welder to run the plasma.  I end up using O/A about half the time.  Cyberweld has a small O/A kit for $161 (cuts up to 3" with larger tips).  Larger kits for thicker cuts are $230 and up.  Large tanks will probably cost $500 for the pair.  So for a few hundred less than the plasma you get equipment that cuts a few *inches* of thickness, can weld, heat, and you can take it places without compressed air or big electrical supply.I'd buy the O/A first, then buy the plasma for convenience and sheet metal.  It is nice to pull the trigger and cut without making any adjustments or waiting for preheat.  It's also nice to lay the plasma torch down anywhere and not worry about what might catch fire (I do a lot of farm stuff and there's always grass or hydraulic hoses, etc).Edit: the more I think about it.  5/8" cut would do 90% of my work.  The next machine up, cutmaster52, is $1567 compared to $915.  That's a significant step in the money.  Of course the cm52 has a recommended cut of 1/2" and a max of 1-1/8".  It is almost double the machine.  It's a toss up.  Buy the smaller machine now and risk having to rebuy later, or buy the larger machine now and be done with it.Last edited by AndyA; 04-10-2012 at 11:47 AM.Dynasty200DX w/coolmate1MM210MM VintageESAB miniarc161ltsLincoln AC225Victor O/A, Smith AW1ACutmaster 81IR 2475N7.5FPRage3Jancy USA1019" SBAEAD-200LE
Reply:Here's my local supplier. Check them out. http://www.weldersupply.com/products...tting+Machines.Before buying read through the Hypertherm under the manufacture forum. Great reading and you may find more answers to the questions you didn't think to ask . I'm a Miller guy but the 45 is what you really want. Save a little longer and you will get so much more. No, I don't work for them but enjoy working with high quality products and service that Hypertherm provides. You will see in many Miller and Lincoln  welding machines  shop pictures with a Hypertherm next to it. . good luck in your choice. Choose wisely it's a big investment.     HYPERTHERM POWERMAX45  $1550.00  FREE SHIPPING (LOWER 48 STATES)
Reply:All good info. I work for Hypertherm.....and I agree that an Oxy-fuel setup should be owned before a plasma.....unless maybe all of your cutting is under about 3/16".....and you never have to use a torch for heating.Comparisons between brands....the Powermax30 (Hypertherm) (USA) is closely comparable to the Cutmaster 42 (Import)....in fact the 30 has more power when running on 120 volts than the 42.....but the 42 has slightly more power on 220 volts.The Powermax45 has similar or more power as compared to the Cutmaster 52. Prices are almost the same between these two because American salaries and benefits are paid to the assemblers. I keep a Powermax30 on a welding cart with one of my Mig's (Hobart HH20).....It does everything I need for the majority of cutting jobs I do.....I never use oxy-fuel for any cutting (I have a Powermax85 whan I need heavier cutting than the 30 can handle)....but I use the oxy-fuel often for heating/bending, loosening rusty fasteners and the like. The 30 is a pretty good cutting tool up through 1/4" (same for the CM42).....and each will sever 5/8" (good enough for severing bolts, etc.).I'd mention all of the other Hypertherm advantages over the T-D's.....but I could be accused of bias!Jim Colt Originally Posted by AndyANo problems from cyberweld.  I've bought a few big $$$ items from them and tons of little stuff.  No problems on any of it.  I even had them call me one time to double check there wasn't a screwup (and there wasn't).I'm not sure what stuff you work on, but I wouldn't buy a plasma with a max cut of 5/8".  Even if it means waiting and saving your nickles, I think you'll be happier in the long run with something a little bigger.  If you have a bigger one that has fine cut consumables you get the best of both worlds.  Big current, big consumables for the thick material.  Turn down the current and use fine consumables to get a small kerf and clean cut on thin material.Do you already have an O/A setup?  For hand cutting a good O/A setup will do just as nice of work as the plasma.  I have O/A on the truck since I don't have an air compressor or enough generator on the welder to run the plasma.  I end up using O/A about half the time.  Cyberweld has a small O/A kit for $161 (cuts up to 3" with larger tips).  Larger kits for thicker cuts are $230 and up.  Large tanks will probably cost $500 for the pair.  So for a few hundred less than the plasma you get equipment that cuts a few *inches* of thickness, can weld, heat, and you can take it places without compressed air or big electrical supply.I'd buy the O/A first, then buy the plasma for convenience and sheet metal.  It is nice to pull the trigger and cut without making any adjustments or waiting for preheat.  It's also nice to lay the plasma torch down anywhere and not worry about what might catch fire (I do a lot of farm stuff and there's always grass or hydraulic hoses, etc).Edit: the more I think about it.  5/8" cut would do 90% of my work.  The next machine up, cutmaster52, is $1567 compared to $915.  That's a significant step in the money.  Of course the cm52 has a recommended cut of 1/2" and a max of 1-1/8".  It is almost double the machine.  It's a toss up.  Buy the smaller machine now and risk having to rebuy later, or buy the larger machine now and be done with it.
GMT+8, 2025-12-24 10:57 , Processed in 0.106741 second(s), 18 queries .
