weld thickness
发表于 2021-8-31 23:54:04 | 显示全部楼层 |阅读模式
im doing a suicide door on the back of my 91 caprice i want to use 1/8 inch plate to remake the door jam for strength. I would like to know hoe i could weld the 1/8 plate to the 16 gauge body steel. Is it like most body work just a bunch of tacks till full.Im using .030 co2 wire no flux with weld primer.
Reply:Small hot tack, repeat, repeat................... .
Reply:so the same as everything ive done to body work tack, tack, tack, ect....... good
GMT+8, 2025-12-24 11:03 , Processed in 0.072029 second(s), 18 queries .
