Finger Press Brake
发表于 2021-8-31 23:53:43 | 显示全部楼层 |阅读模式
These are some shots of a finger press brake I made a while back. It's capable of 30" wide and about 6" deep box. So far I've done 10ga with it but with the right bottom die I could do more. As you can see in the second shot I've got both 45 deg and 60 deg on the ends of the upper dies. The bottom die has both as well. In the third shot you can see the way I made the hinge adjustable.You can also see my bottom die for up to 4 1/2' of 10 ga. It's used with the top die you see in the fourth shot. Also in the fourth shot is the original bottom die made to bend 3/16" plate for a front end loader bucket using the same top die. These are used in the large press in the back ground. For better shots of the press go to my web site in the sig.  Enjoy. Attached ImagesMillermatic 252XMT 304'sDynasty 280DXHypertherm PowerMax 1250Miller Trailblazer 302 EFIOptima PulserXR feeder and XR Edge gun and more athttp://members.dslextreme.com/users/waynecook/index.htm
Reply:Very nice!  Quick rescue it before the plants take over.  Heh!
Reply:Thanks.   Yeah I've got to get that spray rig going. :-)Millermatic 252XMT 304'sDynasty 280DXHypertherm PowerMax 1250Miller Trailblazer 302 EFIOptima PulserXR feeder and XR Edge gun and more athttp://members.dslextreme.com/users/waynecook/index.htm
GMT+8, 2025-12-24 10:40 , Processed in 0.069282 second(s), 18 queries .
