Rod holder mounts
发表于 2021-8-31 23:53:41 | 显示全部楼层 |阅读模式
Anyone got a cool tip to make some good looking 36" rod tube holder/brackets?  I am finishing up my cart and figured I would just dice up some 2" round tubing to use as a holder for the tube to slide down into... Unless the experts here already know of a cool bracket that already exists.
Reply:These are nice.  Attached ImagesCity of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:I used a sheet of 16ga. steel. Holes for the PVC tubes done with a Greenlee knockout punch.90 degree lip on the backside drilled to match up with cover screw holes on the SW255.Rex
Reply:That Lincoln machine has got me drooling on my keyboard. That's a nice machine!! And the rod holders look good too.  I used capped PVC tubes that I mark for what rods are in them, I did not mount them on my machine, I don't move my machine around much.
Reply:rode2rouen:  That is a great idea.  I will have to use a lower tech approach and hole saw the cut-outs but should work just fine.  Thanx.tanglediver:  Those rod holders are waaaay cool.  It's the price of the "rod holder" ""holder"" that keeps me out of your league......
Reply:Originally Posted by Kaiser26k3rode2rouen:  That is a great idea.  I will have to use a lower tech approach and hole saw the cut-outs but should work just fine.  Thanx.tanglediver:  Those rod holders are waaaay cool.  It's the price of the "rod holder" ""holder"" that keeps me out of your league......
Reply:Originally Posted by rode2rouenI used a sheet of 16ga. steel. Holes for the PVC tubes done with a Greenlee knockout punch.90 degree lip on the backside drilled to match up with cover screw holes on the SW255.Rex
Reply:Rode2,I'm basically a Blue machine guy, but had a couple questions about the Lincoln.Does the torch really plug into the side of the machine instead of the front?  Seems it would be very susceptable to being damaged in moving the machine around.What gauge cord did you use for primary input power?  Looks pretty small in the photo.Syncro 250 DX Dynasty 200 DXMM 251 w/30A SG XMT 304 w/714 Feeder & Optima PulserHH187Dialarc 250 AC/DCHypertherm PM 1250Smith, Harris, Victor O/ASmith and Thermco Gas MixersAccess to a full fab shop with CNC Plasma, Water Jet, etc.
Reply:Originally Posted by ItsAdam1Where can I get a knock out punch?
Reply:Similar to rode2rouen's, here's my version.You can get the whole story here: http://weldingweb.com/vbb/showthread.php?t=26494MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
GMT+8, 2025-12-24 10:38 , Processed in 0.091040 second(s), 18 queries .
