BBQ I Built
发表于 2021-8-31 23:53:26 | 显示全部楼层 |阅读模式
So a coach at my school wanted a barbecue built.  My name was mentioned.  I built it in my college welding class.  Tomorrow we are grilling on it at welding class.
Reply:That sure looks like s.s. except for the grill.  Nice job.Common sense in an uncommon degree is what the world calls wisdom.
Reply:Originally Posted by BrainfarthThat sure looks like s.s. except for the grill.  Nice job.
Reply:Originally Posted by bert the welder...and you are using "s.s." to stand for what..........?
Reply:+1, nice work with the handles and feet.Matt
Reply:Thanks for the comments.  It's my first major project and first barbecue.  My teach told me how to build it and then I did all the work.
Reply:Sweet, might need wheels to move it.
Reply:Were you backstepping the welds, or whatever it's called, on the lid?One day, before they shovel dirt in my face, I 'd like to build a BBQ Attached Images"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Originally Posted by farmersammWere you backstepping the welds, or whatever it's called, on the lid?
Reply:Originally Posted by sean9721I'm not really sure what you mean.As for wheels, the coach didn't want any.
Reply:I just welded in 1 direction.  The reason the humps are there is because I went over the tacks.
Reply:Originally Posted by sean9721I just welded in 1 direction.  The reason the humps are there is because I went over the tacks.
Reply:nice grill. I built this out of two old propane tanks i picked up its a real conversation starter Attached Images
Reply:did you put any vents or dampers below on your bbq??? That would really help out on controling your temps? Nice work alsoJerodHypertherm 30Miller Syncrowave 200Millermatic 140and a propane torch and hanger if all else fails
Reply:There is a vent on the side to control air flow.
GMT+8, 2025-12-24 10:34 , Processed in 0.090559 second(s), 18 queries .
