Canfield SBC head crash repair
发表于 2021-8-31 23:53:25 | 显示全部楼层 |阅读模式
Canfield head off a dirt track car. Had a valve to piston crash, broke ex valve seat, intake guide boss, and peckerized that combustion chamber.Pre and post heat at 350 degrees, weld with A356 filler, machine and grind to taste. Attached Images
Reply:Last two. Attached Images
Reply:man, you do marvelous repairs!  although, every single one of your posts sounds like a recipe for grill chicken pre-heat oven to 350, bake for 45 minutes, turn over half way through, and post heat 350 for another 45 minutes.  cheers
Reply:What's the advantage of using A356 filler?  And why do you pre-heat your aluminum heads?  I've never pre-heated any of my cast aluminum parts and they seem to be holding fine.Common sense in an uncommon degree is what the world calls wisdom.
Reply:Originally Posted by oxy moronman, you do marvelous repairs!  although, every single one of your posts sounds like a recipe for grill chicken pre-heat oven to 350, bake for 45 minutes, turn over half way through, and post heat 350 for another 45 minutes.  cheers
Reply:like always, another great repair.
Reply:Originally Posted by jreynoldsweldinglike always, another great repair.
Reply:Great looking repair    May i ask where you are getting your a356 filler ?  thanks Jake
Reply:Originally Posted by jakesportingGreat looking repair    May i ask where you are getting your a356 filler ?  thanks Jake
Reply:thanks i'll have to look them up  Jake
GMT+8, 2025-12-24 10:36 , Processed in 0.114984 second(s), 18 queries .
