I'm new to this whole welding thing i have been interested in welding for a while but don't know what to buy i wanna start buy building a tubing bender then a off road dune buggy craZY ideas in my head but any ways dose any know what this is LINCOLN WELDER WIRE FEED SYNERGIC 7 http://www.ebay.com/itm/LINCOLN-WELD...item1c26058498 here is a link to what i wanna buy if its a good welder any input would be appreciated thanks a lot in advance
Reply:Hello Mr Biggs, the link that you included is for a feeder only, you would then need a power source to hook it up to. I am not up on Lincoln products, but from the product description, that particular feeder is likely designed to be used with one of Lincoln's higher end power sources. "Synergic" typically refers to welding systems that are able to be adjusted with one dial in order to change overall welding characteristics as opposed to most machines where you adjust: voltage, wirespeed, and other parameters with individual dials or switches. To make the system work that you have the link for you would need to invest quite a bit more money into additional components. Others can likely shed more specific information on this for you. Best regards, Allanaevald
Reply:thank you sir for your help |
