As seen on TV Infomercial. How to: Weld, drill, tap, and fab aluminum
发表于 2021-8-31 23:53:14 | 显示全部楼层 |阅读模式
In case you missed today's aluminum welding infomercial, here are a few highlights:.Attachment 26714Attachment 26715That's a propane torch tip:Attachment 26716Attachment 26717Attachment 26718Last edited by denrep; 10-19-2010 at 11:37 PM.
Reply:Attachment 26719In this set she was welding an ear back on a transmission case:Attachment 26720Attachment 26721Attachment 26722Last edited by denrep; 10-19-2010 at 11:37 PM.
Reply:Attachment 26723Attachment 26724Attachment 26725Attachment 26726She even welds beverage cans Attachment 26727Last edited by denrep; 10-19-2010 at 11:37 PM.
Reply:Attachment 26733Strong enough for the prop:Attachment 26734And the ladder too!Attachment 26735Attachment 26736Attachment 26737Sorry about the picture quality, these were shots of the TV screen.I'm not sure how much we missed, she was welding the boat prop when I walked in!Who said you can't learn anything watching TV?  Last edited by denrep; 10-19-2010 at 11:37 PM.
Reply:Yup, AULMALOY!! i havent seen this on in a looooong time!! I wonder how will it works? Last time i seen it on was prob like 5 years ago.
Reply:Originally Posted by welderShaneYup, AULMALOY!! i havent seen this on in a looooong time!! I wonder how will it works? Last time i seen it on was prob like 5 years ago.
Reply:it is the same as hts 2000, durafix and other fluxless aluminum brazing rods.  good stuff for what it is worth.
Reply:I've seen people doing demo's at flea markets to sell this stuff.  Guys I know that have bought it say that it is not nearly as easy as they make it look.Proud to be a UNION worker.  Better pay, better benefits, better work environment.  UA Unions = working for the working class!!
Reply:Did Alfred thank the nice lady for the demonstration? Attached Images"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Originally Posted by EngloidI've seen people doing demo's at flea markets to sell this stuff.  Guys I know that have bought it say that it is not nearly as easy as they make it look.
Reply:Its strong as hell. But then again it is mostly zinc. A couple ingredients different and its spot galvanizing. My favorite to do is repair threads in a blind hole. Heat the hole, set the bolt in and heat it some and start filling the area around the bolt. Let cool and remove the bolt as if the threads were never damaged. There is also a rod that works on steel, cast and stainless made by the same manufacture. Great for fixing jon boats.
Reply:Denrep was that the commercial with the woman narrating it?Im loving the picture where it says "Ladder repair" Yup! Thats what I would do if I was selling stuff to people who bought stuff off T.V."Here, use this to fix a ladder" Just make sure you have enough left over to repair your neighbors scuba tank.
Reply:Yuck,  Zinc pot rod......spent many an hour undoing the damage caused by people at that stuff. Its got one use...welding pot metal...and I use it for that! It has no ductility...and can cause the base aluminum to become brittle. If you want to braze aluminum, use aluminum/slilcon brazing material, If you want to weld it, use aluminum filler.....geesh.-Aaron
GMT+8, 2025-12-24 12:28 , Processed in 0.104116 second(s), 18 queries .
