money to spend
发表于 2021-8-31 23:53:13 | 显示全部楼层 |阅读模式
Got some early christmas money and want an opinion please.I have a MM140 which is great but want to be able to do aluminum. I was thinking of upgrading to something like a DVI2, or 212, or maybe a used 252.At the same time thought that it would be fun to learn to tig!!Any ideas?
Reply:You could always buy something for me
Reply:Or you could keep it and by the Spoolmate™ 100 Series. Here is the link: http://www.millerwelds.com/products/...te_100_series/O/A Set-Up Radnor Gauges WH26FC  Welding Torch CA25       Cutting Attachment 0 TipThat is it for now...More to come later...
Reply:Send it to me, send it to me........
Reply:Wow, I don't know what I would do. I have the Miller DVI2 which replaced my old MM130. I love it and use it a fair bit, but I just purchased a Lincoln PT225 tig a couple month ago. Tig welding is amazing and so fun. I guess you are going to need to figure out what your future projects and goals are going to be. One thing about a good Tig welder is that you can use it to stick weld for thicker stuff that the 110 mig can't do so after saying this I might tend to lean toward the tig if you are a good stick welder. The only hold up I see with this idea is the a decent tig is going to cost a lot more then a good mig. Make sure if you do decide to get a tig, it is a good one, it really does pay. I had a cheap one to start with and after getting the PT225, well I couldn't believe the difference. God luck with your choices and I really hope you make the right one for you.Miller DVI2Lincoln Precision Tig 225Thermodynamics Cutmaster 38Everything else needed.
Reply:tig is  where its at.. TA 185.........
Reply:TIG is slow. But the complete control is addicting. If you're going to be welding brackets, widgets and gizmos, TIG wins. Like Jamlit said buy a good one and they are expensive.If you want to build a trailer buy a 220v MIG.9-11-2001......We Will Never ForgetRetired desk jockey. Hobby weldor with a little training. Craftsman O/A---Flat, Vert, Ovhd, Horz. Miller Syncrowave 250
GMT+8, 2025-12-24 16:43 , Processed in 0.092180 second(s), 18 queries .
