random work
发表于 2021-8-31 23:53:10 | 显示全部楼层 |阅读模式
this is just stuff to show to progress.I'm aware it sucks.By laxer11attack at 2010-05-21this is my brazing LITERALLY my first two goes everthe one on the bottom was my first go round and the top one was my second.By laxer11attack at 2010-05-21same set up. bottom has no real penetration the top one has obvious penetrationBy laxer11attack at 2010-05-21this shows my first go with a cutting torchBy laxer11attack at 2010-05-11this shows my cutting a couple weeks laterThis was done right handed by the wayBy laxer11attack at 2010-05-11the edge was touched up with a grinder but it shows how much better I cut lefty.
Reply:practice makes perfect my friend don't worrie it will all come with timeLincoln Pro Core 125Lincolin sp 100Miller Big 40Lincoln Idealarc SP250miller matic 212http://www.facebook.com/hdwelding?sk=wallwww.hdweldingbeds.com
Reply:When brazing, grind the area to be brazed. Brazing works by capillary action in which the base metal "opens up" and the brazing flows into the micropores and scale and rust severly limits this. A little practice and you will look like an old pro.Millermatic 200Hobart Handler 120Victor O/A & Ramco BandsawLincoln 225 ACSnapOn AD HoodMiller XMT304/22AHypertherm Powermax 1650 G3Lincoln Idealarc DC600 w/Extreme 12 VSMiller Digital Elite "Joker"
Reply:One thing I could not make out completely. Did you braze a butt joint? I ask because brazing is backwards from welding. When welding its butt where you can and lap where you must. When brazing its lap where you can and butt where you must. Its part of the capillary action RaptorDuner mentioned.
Reply:Originally Posted by browncoatOne thing I could not make out completely. Did you braze a butt joint? I ask because brazing is backwards from welding. When welding its butt where you can and lap where you must. When brazing its lap where you can and butt where you must. Its part of the capillary action RaptorDuner mentioned.
Reply:Originally Posted by bert the welderor "brazing" and "braze welded"
GMT+8, 2025-12-24 12:22 , Processed in 0.098522 second(s), 18 queries .
