Press pin
发表于 2021-8-31 23:53:09 | 显示全部楼层 |阅读模式
Digging around in boxes has me feeling like a "has been".Below pictures were taken around 1990-91. It's a con-rod pin for a 4000ton National forging press. The pin was machined to remove fatigued material and built up with Weld Mold 535 3/32" cored wire. About 300lbs applied.That fella filling the sub-arc hopper and a small group of employees bought the company a few years after I left them, and are doing well. "Gotta love that"!Matt Attached Images
Reply:I love seeing this kind of stuff!  Thanks!!www.lindgrensupercars.comMiller Dynasty 350Miller Dynasty 200DX - retiredMiller Millermatic 210Miller Spectrum 3080Miller "Power of Blue" stool  Miller Syncrowave 180SD - retired
Reply:Man, I have NO FREAKIN' CLUE what you just said or what 'exactly' that thing is, but it's PRETTY cool none-the-less!Cheers,Miller Diversion 165120 amp Buzz BoxVictor Oxy/Ace Oxy/LPGSmith "Little" Oxy/LPGHypertherm Powermax 30Lot's of Misc. tools n' crap....
Reply:Originally Posted by jmanMan, I have NO FREAKIN' CLUE what you just said or what 'exactly' that thing is, but it's PRETTY cool none-the-less!Cheers,
Reply:Originally Posted by kjlindgrI love seeing this kind of stuff!  Thanks!!
Reply:Originally Posted by MoonRisetranslation :  Here is a pretty big diameter steel pin, for a pretty big press.  It was buggered/knackered/screwed-up.  So the OD of the pin was reduced (most likely via cutting on a lathe) and then it was built back up with about 300 pounds of added weld metal (via the SAW aka sub-arc welding process).  Then that big pin with all the added weld metal was taken to a lathe and the OD was machined back to the 'correct' desired dimensions and the pin then put back into the big press and the press could then be put back into service.
Reply:Originally Posted by 7A749Yup.VERY cool.We have a shop here in town that rebuilds presses.Big presses.http://www.verson.com/repair.htmThat stuff never gets old. The bigger, the better.
Reply:I ran a sub arc welder not that size but the idea was the same. It had 2 welding heads on it. 5/32 wire was normal size....BobBob WrightSalem, Ohio  Birthplace of the Silver & Deming Drillhttp://groups.yahoo.com/group/southbend10k/http://groups.yahoo.com/group/sawking/1999 Miller MM185 w/ Miller 185 Spoolmate spoolgun
Reply:Originally Posted by aametalmasterI ran a sub arc welder not that size but the idea was the same. It had 2 welding heads on it. 5/32 wire was normal size....Bob
GMT+8, 2025-12-24 12:29 , Processed in 0.095765 second(s), 18 queries .
