Please tell me this is a JOKE!
发表于 2021-8-31 23:53:08 | 显示全部楼层 |阅读模式
WTF? is this guy doing. I was on the web and found this.http://www.pond5.com/stock-footage/4...the-field.html
Reply:What's you problem I think that I did just fine welding that pipe together so that it just pops apart with just the littles amout of pressure. Just listen to that baby burn in all sweet sounding like pop corn popping. He's on fire baby!!!To many hobbies not enough Cash!!1951 Chevy 1 Ton 9' Pickup resto-mod V8 4x4 1987 Pontiac Fiero GT 3800 V6 ConversionESAB MIgmaster 250www.anthonysautoservice.com
Reply:Originally Posted by AnthonyFWhat's you problem I think that I did just fine welding that pipe together so that it just pops apart with just the littles amout of pressure. Just listen to that baby burn in all sweet sounding like pop corn popping. He's on fire baby!!!
Reply:To think they even charge $75.00 for the HD version of that stock footage.....maybe they did that on purpose, so someone will buy it for a "how not to do it" show     Synchowave 180SD  Bernard 3500SS water coolerMillermatic 200Parker Plasma Tec 40dvOperating Engineers Local 12
Reply:Tools and a lack of skills certainly make for some entertaining videos!!  Rex
Reply:Thats job security for some lucky stiff with an extremely farsighted boss.
Reply:Man he burned that pipe in there good and hot. Notice the skip-welding technique as well.
Reply:Originally Posted by JohnRMan he burned that pipe in there good and hot. Notice the skip-welding technique as well.
Reply:WOW I think my 2 yr old could do better for sureLincoln Pro Core 125Lincolin sp 100Miller Big 40Lincoln Idealarc SP250miller matic 212http://www.facebook.com/hdwelding?sk=wallwww.hdweldingbeds.com
Reply:He's welding MIG on pipe?  There is your problem.
Reply:I think you meant "Skip-tacking technique", yes? The bean counters were probably bitching about wire expenditures. Dude's just being thrifty !!!! At least in the other video ,he finishes the other side with equal precision. 200amp Air Liquide MIG, Hypertherm Plasma, Harris torches, Optrel helmet, Makita angle grinders, Pre-China Delta chop saw and belt sander, Miller leathers, shop made jigs etc, North- welders backpack.
Reply:Originally Posted by 76GMC1500He's welding MIG on pipe?  There is your problem.
Reply:maybe he was texting        thermal arc 252i  -  millermatic 350P -   miller XMT, cp300ts, 30a 22a feeders, buttload of other millers, handfull of lincolns, couple of esabs  -   Hypertherm 1250 G3
Reply:i dont know about the rest of youz, but this video made me feel better about my welding
Reply:I don't even have my welder yet but I feel better about my welding too!!
Reply:Geesh guys, it's a header for a sprinkler system....Mike
Reply:I dont care what he is "welding" its CRAP! And you can use mig on some pipe applications.
Reply:Actually, the dood ain't welding, he's daubing........and pretty badly!Rex
Reply:Hey this is great, don't know what you guys are on about, this guy's welding will make a fortune for someone... Insurance claim or law suite perhaps, shouldn't take too long  At least the video isn't bad.Miller Auto Invision 456 + S-62 wire feederC6240B1 Gap bed lathe16 ft3 air compressor16 speed pedestal drillHafco BS-912 Bandsaw
Reply:How would you like to be the guy that has to X-ray that weld? "Really are you sure you welded this?"
Reply:Originally Posted by oxy moroni dont know about the rest of youz, but this video made me feel better about my welding
Reply:Haha... That guy sure has a steady hand.  It sounds like the new guy pulse/spot welding option.Common sense in an uncommon degree is what the world calls wisdom.
Reply:WOW I thought my welding sucked, but this guy is horrible. (I'm still learning)
Reply:You could probably just knock those boogers off with a file, lol
Reply:Had to watch it again, thought something fishy was going on.........he's doing Morse Code!!!! Synchowave 180SD  Bernard 3500SS water coolerMillermatic 200Parker Plasma Tec 40dvOperating Engineers Local 12Originally Posted by SR20steveYou could probably just knock those boogers off with a file, lol
Reply:I think he was just using the wrong pipe dope for flux trying to weld cast iron to mild steel.
Reply:Anyone got 75 bucks I can borrow?Common sense in an uncommon degree is what the world calls wisdom.
Reply:Nice flat angle technique, and also energy conscious by keeping the amps down.  I have said this before. " The guy welding, notice I did not say welder, should be kicked in the balls at sun rise to a slow drum roll".Last edited by kolot; 05-27-2010 at 02:14 PM."Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:Originally Posted by BrainfarthAnyone got 75 bucks I can borrow?
Reply:Originally Posted by BruceTSHad to watch it again, thought something fishy was going on.........he's doing Morse Code!!!!
Reply:i think it is a threaded fitting
GMT+8, 2025-12-24 12:20 , Processed in 0.118326 second(s), 18 queries .
