Needing a square line on a tube with a large edge radius?
发表于 2021-8-31 23:53:07 | 显示全部楼层 |阅读模式
Hello folks, if you do much work with square or rectangular tube steel and require square lines across the faces of any of the sides this can sometimes be a challenge. Here are just a few ideas to tackle this sort of thing. I have included a few pictures to show these approaches. It's likely that I'll need to make a few posts to include the various items. The last picture shows why a standard square has a hard time giving an accurate line, the radius can play heck with a good reference. Attached Imagesaevald
Reply:Here is another variation that accomplishes the same result, although you could slide the rule in or out and use it to mark various dimension lines or points on the face of the tube. Best regards, Allan Attached Imagesaevald
Reply:here's the missing picture. Attached Imagesaevald
Reply:good idea
Reply:this is my favorite square for wrapping around square tubing http://www.veritastools.com/products/Page.aspx?p=84
Reply:We have some similar looking bits for our squares.  I'll try to post some photos when I get back to the shop.  Some of those tools you have there are not for the new guy.. he wouldnt be able to pick them up. Common sense in an uncommon degree is what the world calls wisdom.
Reply:I 100% see what you're saying.Using a regular framing type square leaves you with having to sight the line for the next mark.  By the end of marking the tubing, you're off on the last line, which is also your cut line   The errors multiply as you mark each side of the tubing.  This is a particularly annoying problem if you torch cut your tubing."Any day above ground is a good day"http://www.farmersamm.com/
Reply:I always use a tri-square.  Also known as a rafter square.My name's not Jim....
Reply:I just mate, hold or clamp, a piece of flat bar or a square blade to side of tube. This provides a guide for the tri-square head.Miller TrailBlazer 251Miller HF-250-1Miller MaxStar 150 STLHyperTherm PowerMax 380 plasmaLincoln PowerMig 180Millermatic 252Miller Diversion 180
GMT+8, 2025-12-24 12:22 , Processed in 0.098092 second(s), 18 queries .
