help for cwb test on monday
发表于 2021-8-31 23:53:00 | 显示全部楼层 |阅读模式
hey everyone.  asking for some assistanceon trying to pass a flat and horizontal flux cored weld tst on monday.  i am using the drag technique and welding heat is about 26 and 4 on the canox machine.  gas is about 35-37.  i am trapping slag all along the edge in my root passes and restarts.  i am trying ti whip out the wire when i stop to avoid the little cave trapped at the end of my weld puddle?  is my backhand angle to much? or wled bead to large is close to 5/16s angle is about 30 degrees backhand and pointing mostly 45 into the joint.  thanks for any help or advice!
GMT+8, 2025-12-24 12:22 , Processed in 0.067886 second(s), 18 queries .
