determining aluminum type
发表于 2021-8-31 23:53:00 | 显示全部楼层 |阅读模式
anyone have any idea what sliding glass door and window frames are made of?? just took a huge 12ft slider and a big window got rid of the glass and figure the frames will make great practice material before they go to the scraper trying to figure what filler to use  etc350P 30A spool gun cut master 51  syncro 250 other stuff " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
Reply:Probably vinyl.Millermatic 211Everlast 200DX Thermal Arc 181iKlutch ST80i lunchbox stick welderLincoln Weld-Pak 100Century Stick welderPowermax 30 plasma cutterHenrob 2000 torchLogan 200 lathe (60 years old)Clausing 6339 Lathe (for sale)
Reply:Originally Posted by yesindeedProbably vinyl.
Reply:Formed from sheet of some recycled aluminum alloy but 10 to 1 says it's not the real good stuff...I have no idea what it is but it sucks to weld....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Architectural extrusions are generally 6063. I'd bet the sliding door is also 6063.
Reply:6063 for sure;  it could be any one of a number of the 6000 series Al alloys and also any one of a number of tempers.   you can bet that the mfg is going to know what alloy and temper he is going to be pushing through his dies ahead of time.  there is a lot of engineering that goes into the process.i used to buy most of my aluminum from eastern metal supply they carry a huge line of extrusions;  specialty,architectural and structural.  good company.  at least all my dealings with them were, we bought tons of aluminum from them back in the nineties.
Reply:My money is on 5052 for corrosion reasons. It just a shot in the dark
Reply:I know that you get the highest price at the scrappers for extrusions for doors and windows.  Mac
GMT+8, 2025-12-24 12:22 , Processed in 0.098387 second(s), 18 queries .
