emergency help- Flagstaff AZ
发表于 2021-8-31 23:52:59 | 显示全部楼层 |阅读模式
Any one near Flagstaff with a 17' or bigger Box truck?I have a broken down truck out side Flaggstaff and I need to transfer equipment and then take it to AlbuquerqueEd Conley 323-640-3183$$$$$Last edited by Broccoli1; 04-19-2012 at 10:14 PM.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:U haul an option? Good luck man.You have to learn the rules of the game. And then you have to play better than anyone else. Albert Einstein
Reply:3 places in Flagstaff I can get a truck tomorrow am but they're supposed to be in Albuquerque by 9am to start lighting the setMy truck is on the way to a Repair shop now- hopefully they can fix it and get them on their way.It is what it isEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Check the Carter Travel Center truck stop in town.http://www.findfuelstops.com/truck-stop-002602MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Biz partner highballed it with his 26' Trailer last night, got to flaggstaf about 3:30 am and on the road to ABQ about 5am.Seized pulley on the truck Run yer own bizness??? Yeah it is all glamourousEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:It sounds like you got it sorted out Ed.Stressful at times eh?Here's for smoother sailing from here on out. Rick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
Reply:what kind of set are they lighting?There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Our client is shooting all the print photos for Advertising/promo: Billboards, Buses, Bus Stops, Inserts etc.Breaking BadThey Film the series in AlbuquerqueEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:I would have said go up to the Museum Club, North end of town and have a beer... if you had just been there for fun... doesn't sound like an easy afternoon. good luck in NM.Lincoln Power MIG 215Lincoln WeldPak 3200HDLincon ProCut 25Lincoln WeldanPower 225 AC/DCIf all else fails... buy more tools
Reply:Glad you got it saved. And people think self-employment is the dream.........I LOVE that show!!!!200amp Air Liquide MIG, Hypertherm Plasma, Harris torches, Optrel helmet, Makita angle grinders, Pre-China Delta chop saw and belt sander, Miller leathers, shop made jigs etc, North- welders backpack.
Reply:Thankfully the ford idler pulley covers about 100 different applications so A lot of parts houses have them in stock.Glad you got a solution rolling nothing sucks more than having equipment dead in the water far from home.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:hopefully they can fix it and get them on their way
GMT+8, 2025-12-24 12:22 , Processed in 0.096635 second(s), 18 queries .
