air testing unit
发表于 2021-8-31 23:52:50 | 显示全部楼层 |阅读模式
im not exactly sure what this company is doing but i do know it is some sort of air testing unit. Attached ImagesA GRINDER AND SOME PAINT WILL MAKE A WELDER WHAT HE AINT
Reply:that's clearly the exhaust manifold for a car owned by a GIANT.
Reply:It could be a number of things. Are you sure it just isnt going to be air tested? Looks like good work.UA Local 598
Reply:haha yea its a very large exhuast manifold!!  no its not going to be air tested, the company its for does some sort of air quality testing or some sh**.  im just the dumb welder i dont get all the details...lolA GRINDER AND SOME PAINT WILL MAKE A WELDER WHAT HE AINT
Reply:Nice work but , to me, it doesn't look like the flanges were two-holed.  Instead it looks like the flange holes are centered on the center line of the pipe.  Maybe an optical illusion?"The man of great wealth owes a peculiar obligation to the State, because he derives special advantages from the mere existence of government."  Teddy RooseveltAmerican by birth, Union by choice!  Boilermakers # 60America is a Union.
Reply:im not exactly sure what you mean by two-holed??A GRINDER AND SOME PAINT WILL MAKE A WELDER WHAT HE AINT
Reply:Pretty sure he means the flanges are normally set up with the centre of two holes lined up with the centreline of the main spool body instead of the centre of one hole.Hard to explain.
Reply:danielw has it right.  If the pipe is in stands the pipe is leveled and flanges are normally set with pins or bolts in the top two bolt holes and a torpedo set across the pins and leveled, then tacked on top. Then the flange is checked for plumb and tacked. Then the pipe is rolled 1/4 turn and the flange is again checked for plumb and tacked.  If the pipe cannot be rolled then a square may be used to square the flange with the pipe."Two holing"  assures that a section of  pipe with flanges will line up with whatever component it has to mate to when it is fabricated on the ground.  Layouts can get pretty complex with multiple flanges and all must align properly when lifted into position.  If not, a red faced fitter will have some fast talking to do!"The man of great wealth owes a peculiar obligation to the State, because he derives special advantages from the mere existence of government."  Teddy RooseveltAmerican by birth, Union by choice!  Boilermakers # 60America is a Union.
Reply:Check out my ebay store. http://stores.ebay.com/Flangepro
Reply:It may attach to some flex style bellows with rotating flange rings. But it is still a common practice and good idea to two-hole everythingUA Local 598
Reply:oh ok i see what you are saying.  we are a structural steel shop and we dont do a lot of this type of pipe work.  i understand now what you meant.  always good to learn something new.A GRINDER AND SOME PAINT WILL MAKE A WELDER WHAT HE AINT
GMT+8, 2025-12-24 12:51 , Processed in 0.103216 second(s), 18 queries .
