Beater Stand/Work Station and Grinder Stand
发表于 2021-8-31 23:52:48 | 显示全部楼层 |阅读模式
This is my stand for holding my hammers/dollies/beater bags. I used an old tool stand that my dad gave me when I visited him in April it's very sturdy and heavy. I used some angle iron for the hammer holders on both sides, the one side I tapered the angle on the inside to accomidate larger handles the other side I kept parallel. I welded square tubing down the center of the top from front to back leaving it sticking out a bit in the front for mounting some dollies horizontal, then welded 2 pieces of square tubing vertically for both mounting dollies and future tools such as bead rollers and a bench top wheel. I drilled holes in the tubes and welded nuts on so I can clamp things tight. I'll paint it after I think I've added all I might want to itThis is my grinder stand and a good stand for a beater bag also. I just welded small square tubing in 4 directions pointing to the corners of the top then welded small horse shoes to hold the grinders, gonna put a square tube inside the round one to hold a beater bag platform so it can double up on its usage.
Reply:Like the horseshoe idea!(Retired) Professional firefighter, amateur everything else I try to do...Oh yeah:  Go Big Red!   (You know: one of the 12 members of the Big 10 cuz we left the 10 members of the Big 12...)
GMT+8, 2025-12-24 16:53 , Processed in 0.071350 second(s), 18 queries .
