A Quickie for the truck
发表于 2021-8-31 23:52:48 | 显示全部楼层 |阅读模式
Nothing complicated here, in fact I got this idea from one of you fellows on this board.  Had some spare diamond plate and a few pieces of receiver tubing.  Also prevents knubnuts in parking lots from banging into your bumper. If they do try it will leave a mark.
Reply:I like it.  If I had a truck I would build one too  The Lord has declared, "This is my work and my glory--to bring to pass the immortality and eternal life of man"  Moses 1:39Link: My name is John, and I am a member of The Church of Jesus Christ of Latter-Day Saints.-- ColdCreekWorks.com --
Reply:Very nice! Specs? I have a 95 Z71 that'd I'd like to build one for. Thanks!
Reply:Looks good.  Great idea, I might have to do that too.
Reply:Specs:2" Receiver Tubing 1/4 wall1/4 diamond plate45 degree angles (making the cuts 22 1/2 degrees)Welded with 7018 rodPowder Coated Black Receiver was drilled for a 1" dia CR Rod and tapped 5/8 - 11 for round head allen's that go in from either side. I did this rather than having a bolt or rd running through it.  More of a flush setup. Holler with any other questions.
Reply:Thanks! Looks very clean and professional.
Reply:So if ya want to tow something, ya have to carry a wrench?My name's not Jim....
Reply:Allen wrench, but not many thieves run around with a set of large Allen's.The chances of me towing stuff are slim to none, and slim left town.
GMT+8, 2025-12-24 12:51 , Processed in 0.071451 second(s), 18 queries .
