14 pin miller plug on a sa200 1978
发表于 2021-8-31 23:52:45 | 显示全部楼层 |阅读模式
any body try to install a 14 pin plug on a sa 200. I have a 30amp spool gun in shop but would like to use on portable. the gun uses only 3  pins ,instead of buying new portable miller welder.::
Reply:You are going to need a lot more than just the connector to run a CV powered spoolgun from a CC power source. They have made some spoolguns in the past designed to run from older CC power sources, but they don't run anywhere near like a spoolgun does from a CV machine. Most don't end up getting the results they expect after spending a bunch of money on something like this..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:thanxs for the info, didnt think it would work ,but there seams to be a lot of good info on this site ,you never know what somebody has dreamed up.
GMT+8, 2025-12-24 12:50 , Processed in 0.088156 second(s), 18 queries .
