Bushings/Bushing pipe -- Where to buy
发表于 2021-8-31 23:52:44 | 显示全部楼层 |阅读模式
Wondering if any of you have a cheap place to buy steel bushings with a 5/8" ID, 1" OD, and preferably in lengths measured in feet?I found some 2.25" long bushings on a site (bought them too) for about 3-5 each (can remember exact amount).  I figured there has to be a cheaper way.The Lord has declared, "This is my work and my glory--to bring to pass the immortality and eternal life of man"  Moses 1:39Link: My name is John, and I am a member of The Church of Jesus Christ of Latter-Day Saints.-- ColdCreekWorks.com --
Reply:DOM tubing in the OD/ID you want, they sell it by the foot online or metal suppliers can get it.www.discountsteel.com has it for around $11.50ft
Reply:Originally Posted by ironmangqDOM tubing in the OD/ID you want, they sell it by the foot online or metal suppliers can get it.www.discountsteel.com has it for around $11.50ft
Reply:1"OD with 5/8"ID is 3/16" wall which is what I looked up there. a 10' stick will run ya $70 + shipping, longer lengths are cheaper still a 17' stock length with no cut runs $6.50 a foot. 1" comes in wall thickness from 18ga to 5/16" from them.
Reply:Originally Posted by ironmangq1"OD with 5/8"ID is 3/16" wall which is what I looked up there. a 10' stick will run ya $70 + shipping, longer lengths are cheaper still a 17' stock length with no cut runs $6.50 a foot. 1" comes in wall thickness from 18ga to 5/16" from them.
Reply:If you want 3/8" wall with a 1.0" OD you end up with a 1/4" hole.  I think you are subtracting the 5/8 from 1" to get the 3/8" but then you must divide by two to get the wall thickness which will be .187 or 3/16.  Maybe I'm missing something.Dan
Reply:Ah, I believe you are right.......  What you said makes sense....  OK, let me go and look into it now with that clarified.  Thank you.The Lord has declared, "This is my work and my glory--to bring to pass the immortality and eternal life of man"  Moses 1:39Link: My name is John, and I am a member of The Church of Jesus Christ of Latter-Day Saints.-- ColdCreekWorks.com --
GMT+8, 2025-12-24 12:50 , Processed in 0.079108 second(s), 18 queries .
