Fixing sctraches in mill finish alum
发表于 2021-8-31 23:52:43 | 显示全部楼层 |阅读模式
We do not work with mill finish much and we do not have non-marring dies for our brake. What is the best method for working scratches out of mill finish alum?Dynamic MetalworksMontrose, CODynMetalworks.com
Reply:Try using slipsheets, (either rubber, Alum, or even tyvek if it's thin enough) spray with a bit of wd-40, it shouldn't need rework after.Make sure to file off any burrs on your dies also.Last edited by WeldingMachine; 04-26-2012 at 07:05 PM.Reason: yo mamaBuy American, or don't whine when you end up on the bread line.
Reply:Will try that next time. Already bent the pieces so need to fix these. thanksDynamic MetalworksMontrose, CODynMetalworks.com
GMT+8, 2025-12-24 16:53 , Processed in 0.131062 second(s), 18 queries .
