Galvanized Metal
发表于 2021-8-31 23:52:40 | 显示全部楼层 |阅读模式
Just started a job welding on cell phone towers everything is galvanized,anybody have any tips on using 7018 rods on galvinized metal,it is definatly tricky.
Reply:Canadian code requires removal for a set distance on each side of weld.  I am not sure for your AWS code.  Welding through zinc will not give you a sound structural weld with E 7018.
Reply:We use 7016 on parking structures, works real good.
Reply:This has some info that could be helpful to you, although it doesn't mention specific electrodeshttp://www.sperkoengineering.com/htm...Galvanized.pdfEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Hold your breath. Peeee yeeeeew!I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Originally Posted by Broccoli1This has some info that could be helpful to you, although it doesn't mention specific electrodeshttp://www.sperkoengineering.com/htm...Galvanized.pdf
GMT+8, 2025-12-24 12:51 , Processed in 0.104302 second(s), 18 queries .
