I am wondering if the info here is correcthttp://www.rodovens.com/welding_arti...techniques.htmThey say one rod should produce 1 inch of weld bead. That seems short to me. I end up with about 3 inches of bead for each rod.
Reply:seems like a dumb statement. i can depending on travel speed get a lot more from a rod..depends i guess on the width of the bead you are laying down. to use a rod and get a one inch bead i think it would be a pretty wide bead.
Reply:Yeah that is really dumb. What I learned in school was basically if you burnt down 8 inches of rod you should have close to 8 inches of weld (with stringers).
Reply:Might be 3 inches if your weaving going and 9-12" when your running flat. Too many variables to say exactly. My guess is that they might of made a typo a foot instead of an inch makes mor sense.Tough as nails and damn near as smart
Reply:I don't think it was a typo it says it further down the page, after reading it they are just trying to sell you a rod oven. I think they had some kid in the office write a bit of script and he couldn't read the notes he had to write from. Back in trade school they told us that you should be able to make a weld the same length as the amount of the rod used, haven't found that to be completely accurate, as stated above, there's just too many variables.- If you can jump across it you can weld it! - anonymous old boilermaker
Reply:People will say that there's no such thing as a dumb question.That's got to be one of the dumbest questions I've heard asked in awhile.It's kinda like asking someone how long this piece of bubble gum will last.Syncro 250 DX Dynasty 200 DXMM 251 w/30A SG XMT 304 w/714 Feeder & Optima PulserHH187Dialarc 250 AC/DCHypertherm PM 1250Smith, Harris, Victor O/ASmith and Thermco Gas MixersAccess to a full fab shop with CNC Plasma, Water Jet, etc.
Reply:If you're only getting 3" of weld from a rod, you are doing several things wrong.The website mentioned is a literal font of bad information.As my Dear Old Dad used to say, "don't believe everything you read".JTMcC.
Reply:I sent them an email letting them know their information is incorrect and misleading. I think the info on keeping rods other than low hydrogen rods dry is also an error. Most likely to help sell rod ovens.
Reply:[afff
Reply:stop everything.. david r just posted that hes getting 1.25 inch of bead from one rod...1/2" fillet vert up...
Reply:Check this out...http://www.rodovens.com/products/k-3...gren-purge.htmFrom the link in the OP.So, how many of you guys store your TIG and MIG wire in nitrogen purged ovens? I bet they don't sell many of those.Miller EconotigCutmaster 38Yes ma'am, that IS a screwdriver in my pocket! |
