The new BBQ smoker
发表于 2021-8-31 23:52:28 | 显示全部楼层 |阅读模式
I was the guy a while back asking how to cut a propane tank. Well I lived! And now I have a rib cooker!It's reverse flow, there is a sheetmetal baffle inside.http://www2.snapfish.com/snapfish/th...NAME=snapfish/RyanI will add another pic in a minute.Last edited by skywest; 06-11-2010 at 06:15 PM.Lincoln PowerMig 180cVictor O/ABandaids and aspirinI don't know what I don't know!?
Reply:OK so this is not as easy as everyone makes it look.StandbyLincoln PowerMig 180cVictor O/ABandaids and aspirinI don't know what I don't know!?
Reply:Try 2http://www2.snapfish.com/snapfish/sl...NAME=snapfish/http://www2.snapfish.com/snapfish/sl...NAME=snapfish/Lincoln PowerMig 180cVictor O/ABandaids and aspirinI don't know what I don't know!?
Reply:easy to use site for uploading pics i use www.tinypic.com easy as
Reply:www.flickr.comMo bettah. Nice grill btw.
Reply:[QUOTE=skywest;399565]I was the guy a while back asking how to cut a propane tank. Well I lived! And now I have a rib cooker!It's reverse flow, there is a sheetmetal baffle inside.can you explain the baffle? ithought the heat and smoke rose fromthe bottom  box through the top box and out...
Reply:[quote=weldbead;399663] Originally Posted by skywestI was the guy a while back asking how to cut a propane tank. Well I lived! And now I have a rib cooker!It's reverse flow, there is a sheetmetal baffle inside.can you explain the baffle? ithought the heat and smoke rose fromthe bottom  box through the top box and out...
Reply:Welcome to the "cut tank, no boom" club!!! Nice job. I'll get around to making one myself, one of these yearsI'm eye-balling 4 tanks that have been dumped on the corner property down the road from me. Can't ID what kind of tanks they are. They are sitting in the sun and the heat from being in the sun seems to be pressurizing them. Hissing and a bit of liquid coming out one of the bungs. Liquid doesn't smell like fuel/chemical. Not touching them unless I can find out what they are.200amp Air Liquide MIG, Hypertherm Plasma, Harris torches, Optrel helmet, Makita angle grinders, Pre-China Delta chop saw and belt sander, Miller leathers, shop made jigs etc, North- welders backpack.
Reply:Skywest, nice smoker... Maybe some help>  U can post pics directly on the site.. 1. text 5 letters or more2. Go Advanced 3.Scroll down to ~Manage attachments4.Browse and Upload a pic from your computer5. check your work with ~Preview Postall's wellprobably already knew that but pics can be a head scratcher till U see it. enjoy, Smoke some Cabrito ~ a goat shoulder~ brown, smoke, add Oregeno and a rub as needed ... several hours, mmm goodLincoln Power MIG 215Lincoln WeldPak 3200HDLincon ProCut 25Lincoln WeldanPower 225 AC/DCIf all else fails... buy more tools
Reply:Baffle shot:[IMG][/IMG]Lincoln PowerMig 180cVictor O/ABandaids and aspirinI don't know what I don't know!?
Reply:Originally Posted by vandacooteasy to use site for uploading pics i use www.tinypic.com easy as
Reply:Nice job.  The smoke comes out of the firebox, crosses under the food, rises, then crosses back over the food and out the chimney.What size was the propane tank and what's the firebox made of?Lincoln SA 200Esab Caddy 160Thermal Arc 201TSMiller Dialarc HFI don't like making plans for the day because then the word "premeditated" gets thrown around the courtroom....
Reply:Originally Posted by dubl_tNice job.  The smoke comes out of the firebox, crosses under the food, rises, then crosses back over the food and out the chimney.What size was the propane tank and what's the firebox made of?
Reply:[quote=little Jeep;399665] Originally Posted by weldbeadI think I would like to make a smoker.... not sure what I'd smoke, but I like the idea.
GMT+8, 2025-12-24 12:50 , Processed in 0.106158 second(s), 18 queries .
