Homeboy Hold Downs
发表于 2021-8-31 23:52:09 | 显示全部楼层 |阅读模式
A couple of tacky (tacking) hold downs for the tables outer 2 rows of holes.  The middle row will accept an unaltered Jorgenson clamp.  Regular C-clamps and Strong-hand clamps are used on the outer edge of the table. Attached Images
Reply:I like this.You could slide to clamps on the same post opposite each other to hold something up off the table to T into another part.Millermatic 200Hobart Handler 120Victor O/A & Ramco BandsawLincoln 225 ACSnapOn AD HoodMiller XMT304/22AHypertherm Powermax 1650 G3Lincoln Idealarc DC600 w/Extreme 12 VSMiller Digital Elite "Joker"
Reply:those are really nice!!!! Question..... how do you find the holes in your table put up with spatter? Are you having to drill them out often?Thanks,Bert200amp Air Liquide MIG, Hypertherm Plasma, Harris torches, Optrel helmet, Makita angle grinders, Pre-China Delta chop saw and belt sander, Miller leathers, shop made jigs etc, North- welders backpack.
Reply:No problems with spatter.  MIG/Fluxcore only.  No stick.
Reply:I had that same setup at my old shop.  Had a 5' by 10' with holes on 6" centers.   Loved it.Lincoln 300 Vantage 2008300 Commander 1999SA250 1999SA200 1968Miller Syncrowave 200XMT350MPA/S-52E/xr-15Xtreme 12vs Millermatic 251 w/30A  Millermatic 251 Dialarc 250 Hypertherm 1250 GEKA & Bantom Ironwokers
Reply:**** yeah, defently stealing this idea, awsome mate
GMT+8, 2025-12-24 12:52 , Processed in 0.071232 second(s), 18 queries .
