WANT welding table, buy or build?
发表于 2021-8-31 23:52:05 | 显示全部楼层 |阅读模式
I'm very interested in this table. I think it's cheaper if i just buy this than buying materials for building one.On sale for $69, but not sure how much is shipping to Guam. Probably $20-$30 still under $100http://www.northerntool.com/shop/too...7826_200407826Lincoln 140 HD
Reply:If you're going to be welding items that'll fit on the table, then the price is hard to beat.If you're going to be welding larger/heavier items, then you'd have to go larger, or custom.
Reply:Build.that one will be ok for holding stuff up, but it limits your clamping ability, it wont maintain a flat surface, and you wont be able to beat on anything on it. Most poeple end up making attachments for vices grinders, benders, rollers, etc. that table would not have that ability. Thus requiring more space, and more work surface to hold those items. Build your own that will fit the space that you have and allow you the most versitilty possible.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:might be good for a chop saw - I wouldnt use it for a welding tableThermal Arc Fabricator 2101970 Lincoln RedfaceMiller 150 STLStill need a Syncrowave and a plasma and a milling machine and a lathe and a bigger shop and a....
Reply:i'm with the others....build. now i might buy that table purely because it has the expanded metal center with the pan under it. it would be great in the shop during lax time. when i spill my beer the pan would catch it so no mess to clean up. naw i think you gave me an idea for my next table to build for the shop. i'll build it bigger for my poker nights.225NT bobcatAEAD200LEScott 125mm175, mm252 w 30A, PT225mm211, TA 181iHyper Therm 380, cut master 529100X & XX, Digital Elite6 Victor setssmith little torch, meco midget kalamazoo band sawsteel max saw evoulution circular saw
Reply:put a table coth over that thing and serve some tea
Reply:If you need a small, portable table with someone limited maximum load, consider the strong hands one.  It has some wheels on, pretty solid feeling, and has slots which are really handy.  The only thing I don't like is that I think I've warped mine a tiny bit.  I wish the top was a gauge or two heavier.  Its not bad, but if need to restrain some aluminum, I don't think its enough.If you need a setup/fixturing table, get something made with thick plate steel (make your own or hit craigslist).Con Fuse!Miller Dynasty 350Millermatic 350P-Spoolmatic 30AMiller Multimatic 200Hypertherm PowerMax 1000G3Miller Maxstar 200DX
Reply:If you don't have the means to build a proper table and are determined on buying one, take a look at the Arc Station series of welding benches made by miller. At leas they have thicker tops that the one posted and if you go with the X pattern you will be able to use clamps in the middle of it.Mikel
Reply:That table looks cheap and weak.  Plus, it's yellow zinc plated and I'd hate to have any plating on the surface of my welding tables. I agree with others here, build your own.  It doesn't have to look pretty, just sturdy and larger than the one at Northern Tool.   It's not difficult, especially if it's your first welding project.:Lincoln Power Mig 216Lincoln AC/DC-225/125Miller  625 X-Treme PlasmaMiller 211 Forney 95FI-A 301HF 91110Victor Journeyman O/PMilwaukee DaytonMakita  Baileigh NRA Life Member
Reply:You are better off with some metal el' cheapoh depoh saw horses & a manhole cover as a topBuy American, or don't whine when you end up on the bread line.
Reply:Thank you guys, I think i'll build one. I'll use nut and bolt as "feet" so i can level it out in my uneven garage. What do you suggest for adjustability?Lincoln 140 HD
Reply:Originally Posted by toycoma98Thank you guys, I think i'll build one. I'll use nut and bolt as "feet" so i can level it out in my uneven garage. What do you suggest for adjustability?
GMT+8, 2025-12-24 12:50 , Processed in 0.112792 second(s), 18 queries .
