Maybe this is a stupid question... How does the duty cycle of a welder work? Does it alutomatically reduce its voltage. Does it shut off? Am I thinking about this all wrong? It's likely. Reason I'm wondering is I was welding some 1/4" with my Lincoln 180 mig and some times the arc seemed different, not as hot and strong. I thought I might be hitting the duty cylce and the machine was backing off. It is running on a 220 20 amp breaker. Someone set me straight please. Thanks, nick.
Reply:Everytime I have ever pushed a machine to its limit, it keeps running just impossible to use. Its a good time to go for a smoke. haha
Reply:duty cycle means how many minutes out of a ten minute period the machine can weld..a machines duty cycle at full out may be10% or 20% but at a lower output it may be 100%..i dont think it shuts off but just doesnt putout any juice while it recovers..(cools)...
Reply:Why does my nickname have solderer next to it???? Im new here.
Reply:thats why
Reply:gotcha....
Reply:I think I may have been hitting the duty cycle of the machine. Too bad. We'll have to see how the welds hold up. I did multiple passes anyway, because the 180 can't do it in one. I guess I need a bigger machine. Or I should have busted out the Invertec and tried stick welding it. Hate doing that though. Sooo dirty.
Reply:Duty cycle can be either caculated or based on actual run times and temperature measurements. It is the run time vs cooling time (based on ten minutes) a machine can be run at any given output without affecting performance or damaging the machine. Most duty cycles are also based on some where around 104º ambient. So in a way duty cycle is a pretty flakey referrence, but for the lack of anything better it does seem to provide some guide and a way to rate one machine against another. As for the thermal cut-off, that simply means the machine internals (usually x-former) is too hot or at least you have exceeded a temperature the manufacturer has determined to be too high. For instance when a machine goes into the thermal shut down you have already exceeded the duty cycle. The thermal shut down should not be used as a backstop instead of the suggested duty cycle times.
Reply:how can you rate a stick welder on running flat out for 10 minutes? i never saw a rod that long...
Reply:You can duct tape the rods together....sic |
