vert-up mig :)
发表于 2021-8-31 23:51:58 | 显示全部楼层 |阅读模式
in my welding class today we have been doing short-circuit mig on 1/8" mild grade with .035 wire welding t and butt joint vertical up, at first did not like because i suck at weaving but i tried the z-weave and eventuially got the t joint to look almost perfect, very consistent but still a little too convex for my taste, does any body have any tips for making the bead looking more flush17.7 volts215 wire speedalso square groove butt joint tips would be nice, way too convex  and no penetration
Reply:With a vert up weave, in order to get it to be flatter, pause more at the sides and go quicker through the middle.  That is the best way to make it less convex.
Reply:Triangle sometimes called Christmas tree weave.  Only works on a fillet.The metal follows the heat, so when you hit the center, it "sucks the belly in"  Here is an attempt at a video.   Its kind of hard to see, but you will get the idea.  This is pulsed spray, but it works with Mig, and Stick too.[ame]http://www.youtube.com/watch?v=R7V5OCnL48o[/ame]Here is a pic of the same weave.  1/2" fillet, .045 wire @ 145 Inches per minute, around 18 to 19 volts, Co2 gas.  David Last edited by David R; 01-27-2009 at 10:00 PM.Real world weldin.  When I grow up I want to be a tig weldor.
Reply:David,What was that sound?  I never heard anything like that from my ESAB.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:That sound is the pulser.  My 350P makes a similar sound when pulsing.   True spray without pulse is quiet, sounds like a whoooosh.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:This may be of some help :-)http://www.esabna.com/EUWeb/MIG_handbook/592mig7_20.htm
GMT+8, 2025-12-24 16:52 , Processed in 0.277093 second(s), 18 queries .
