Chinese welder excess current
发表于 2021-8-31 23:51:57 | 显示全部楼层 |阅读模式
While going through a bunch of old posts I ran into this thread, which I made a brief comment on.  http://weldingweb.com/vbb/showthread.php?t=18718An individual was having trouble with burn through even at extremely low amperage settings, and I recalled a similar problem that I had encountered.  The welder in question had a front panel nearly identical to the Longevity 200 amp AC/DC pulse unit with plasma that I have been using of late, and I noticed an issue that was very frustrating until I figured out what was going on.After doing some stick welding with the unit, I switched to GTAW mode, and no matter how low I dialed the current, I was having blow through problems on thin wall mild steel tubing.  What I discovered, is that the "Arc Force" knob affects the minimum current output in GTAW mode, but it does not show up on the LED display.  I guess my point is that if you have a similar machine that seems to be outputting significantly more current than you are requesting when in GTAW mode, turn the "Arc Force" knob to zero.As I did not have a clamp on amperage meter, I don't know exactly how big the effect of the "Arc Force" control is for low amperage GTAW, but I know it was definitely enough to make the weld puddle uncontrollable.
GMT+8, 2025-12-24 16:42 , Processed in 0.104662 second(s), 18 queries .
