stainless to cro-moly
发表于 2021-8-31 23:51:57 | 显示全部楼层 |阅读模式
wire selection? i know that 309 is the go to wire for this task but i am curious if their are any other options out their. some one had told me about weldmond 808 but I am curious if this wire is intended for welding dissimilar metals. silver and brass brazing are also options if you have reason to recommend either of those
Reply:All depends on the end-use application.  With stainless and chrom-moly, is this a high stress joint?  Or high temp high stress?  Or corrosive environment?Brazing is potentially bad for these kinds of applications for a few reasons.  But it all depends on the particulars...Don't know anything about weldmond 808 off the top of my head.  Maybe someone else can comment...Benson's Mobile Welding - Dayton, OH metro area - AWS Certified Welding Inspector
Reply:bicycle application; cast stainless 304 dropouts (where the rear wheel attaches to the frame) to cro-mo stays (the rest of the frame) this is a reasonable stressed joints and their will definitely be some flex going on so post weld ductility is important. no heat cycles will happen once in use
Reply:you want Hastelloy W.  AMS 5786
Reply:WHY? not that im doubting you im just one of those people that always wants to know. after doing a little looking it seems like that wires strength is in high temp environments, certainly not something i need but don't think it would hurt. thing is i only need a couple sticks of .045 i think i would get stuck buying a 10# box of that stuffLast edited by quasi; 01-27-2009 at 12:20 PM.
Reply:I'm not a metallurgist, but I deal with them and learn.  Hastelloy W is a good choice because it doesn't require stress relieving after joining different metal types.  It is certainly good for high temp applications(I use it alot on the turbines I weld) but will work great for your application.
Reply:any idea where i can get a couple of sticks?
Reply:These guys sell hastalloy filler metal.  contact them and see if they're send you some samples or name a local distributor.  Or just ask your LWS; mine will often give away a small sample of anything if they have it in stock...http://www.magellanmetals.com/nickel...FSUeDQodQWEglg Originally Posted by quasiany idea where i can get a couple of sticks?
Reply:Silver braze has been the standard for this type of connection for many years, you should probably stick with it.  Ductility is far more important that strength in this application.
GMT+8, 2025-12-24 16:42 , Processed in 0.105672 second(s), 18 queries .
