TIG Torch Parts-Interchangeable?
发表于 2021-8-31 23:51:56 | 显示全部楼层 |阅读模式
If you have an air-cooled torch and have bought things like-gas lenses, collet bodies and collets, and nozzles, Teflon gaskets, etc.....then you buy the same brand of torch in a water-cooled version...are you down to buying all new parts just to fit the new torch?Thanks
Reply:If you go here: http://www.ckworldwide.com/index.htmYou can check out what fits what.Rex
Reply:Less to do with the brand, more to do with the size/rating.  Typically the collets, collet bodies, cups, and tails are going to be the same size.
Reply:Thanks for the replies and info. Much appreciated!
GMT+8, 2025-12-24 16:43 , Processed in 0.096141 second(s), 18 queries .
