Tank
发表于 2021-8-31 23:51:55 | 显示全部楼层 |阅读模式
Just a fun simple project. An radiator overflow tank. If you look there is an unevenness to the top edge. This comes from the buffing wheel throwing it out of my hands 3x on the concrete.
Reply:TIG welded I assume? Looks nice! You gotta be careful with those buffing wheel/grinders. I've lost some skin to both. LOL
Reply:Yes Tig.I count my fingers every time I finish a job!!!
Reply:What material? and where did you get that cap? My father wants an overflow tank for his show car, and I'm getting the parts together.www.thefusionsolution.com
Reply:It is a Moroso weld in cap from Summit:http://www.summitracing.com/parts/MOR-85282/There are a couple weld in caps to choose from Summit, Jegs, etc.The aluminum is .090 and I think it is 3033.
Reply:Drilled, cut and turned the bung for hose fittings:
Reply:looks good!www.thefusionsolution.com
Reply:Thanks!
Reply:i heard of people buying cheap thermo mugs with a screw top made outa aluminium and tigging them to make overflow bottles also, might be a cheap option but wouldn't be as good quality, just another idea
Reply:Deffinantly could have found an easier option but it was a project I wanted to do; and it gave me complete control over the dimensions. I was thinking about doing a perfect cube next. Thought it would be cool for the desk.
Reply:yeah mate, top job also
Reply:I use those caps pretty often though out the year.  I like the aluminum container idea.  Dont forget to clear coat it so you dont loose the shine.Common sense in an uncommon degree is what the world calls wisdom.
Reply:Very nice job. I enjoy seeing good craftsmanship. Keep up the good work.Yes I can tack it for you.    I know that won't hold but that is what you asked me to do.  Millermatic 350P XR Aluma-Pro push/pullMillermatic 185/spool gunMiller Dialarc 250 HF Water cooledThermal Dynamics Plasma
Reply:Very nice job - taking pride in your work shows.
Reply:Originally Posted by BrainfarthI use those caps pretty often though out the year.  I like the aluminum container idea.  Dont forget to clear coat it so you dont loose the shine.
Reply:I dont really have any recommendation for canned stuff because I've had mixed results ('m a welder), so I usually send my stuff to to the powdercoaters.Common sense in an uncommon degree is what the world calls wisdom.
GMT+8, 2025-12-24 16:43 , Processed in 0.071586 second(s), 18 queries .
