welding a head...on the motor...in the truck
发表于 2021-8-31 23:51:54 | 显示全部楼层 |阅读模式
Ford truck, modular motor- common problem. If you have water accumulating under intake manifold it may be coming from pin hole in water port such as this one.While I would usually pre and post heat, it is not a good idea to do so under hood. (FIRE)Welded about 1/2 inch, stop, cool, repeat untill finished.Syncro 250,  4043, 3/32 red tung Attached Images
Reply:Good job....That must have smelled just awful.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Originally Posted by zapsterGood job....That must have smelled just awful.....zap!
Reply:I thought you were welding the head ON the motor not the head on the motor.
Reply:That's one hell of a "pinhole".  Did you have to have someone dangle ya by the ankles to see it while welding?My name's not Jim....
Reply:I'll bet after this job you want if you don't already have one of those lay down over-engine "creepers".  I want one for my shop too
Reply:Pinhole?  There's a freakin' screwdriver through that pinhole!  I'd hate to see what you can a 'moderate hole'.  Never mind what you call a 'major hole'.    Did you do any 'finesse work' to smooth the ID of the water passage after welding that pinhole shut, or was it just try to apply the weld bead kind of smoothly for those first few passes/dips that connected to the ID of the water passage?  And why so much weld bead on the outside of the aluminum intake for just a 'pinhole'?  Was it because the aluminum just didn't want to fuse nicely and you kept having to run wider and wider until you could get a halfway decent puddle without crap in it?  Or was there something else going on with the 'pinhole' that didn't show up until you started getting some welds going?  (casting crack, seam crack, casting porosity, whatever?)  The best laid schemes ... Gang oft agley ...
Reply:Originally Posted by riceburnerI thought you were welding the head ON the motor not the head on the motor.
Reply:Wait a sec... that's a Ranger V6.  Specifically what year and displacement?  I have an '04 4 liter.  I hope I am not seeing my future before my eyes!  -MondoMember, AWSLincoln ProMIG 140Lincoln AC TombstoneCraftsman Lathe 12 x 24 c1935Atlas MFC Horizontal MillCraftsman Commercial Lathe 12 x 36 c1970- - - I'll just keep on keepin' on.
Reply:Originally Posted by MondoWait a sec... that's a Ranger V6.  Specifically what year and displacement?  I have an '04 4 liter.  I hope I am not seeing my future before my eyes!  -Mondo
GMT+8, 2025-12-24 16:42 , Processed in 0.079696 second(s), 18 queries .
