Misc Shop stuff
发表于 2021-8-31 23:51:53 | 显示全部楼层 |阅读模式
A customer wanted me to weld a bunch of goose necks that he had machined out of aluminum for him.  They were fun to weld, but more difficult than I first envisioned.  They were still a little dirty for machining and had tight little corners to get around.  Also, going from 1/4" or so thick on the flanges to a few thousandths for the body was a little tricky on the amperage.Another customer came in with a rack for his truck and I had to take some photos because of the way he mounted it... I kinda like the look.  Maybe longer pieces of flat bar and round bolt heads for an older look would look pretty cool.. Attached ImagesCommon sense in an uncommon degree is what the world calls wisdom.
GMT+8, 2025-12-24 16:52 , Processed in 0.066921 second(s), 18 queries .
