it aint done but it cooks
发表于 2021-8-31 23:51:50 | 显示全部楼层 |阅读模式
first food cooked yesterday Attached Images
Reply:Your mailbox is on fire.    That's the first thought that came to mind when I saw the shape of the grill/food chamber.  It looks like a big mailbox.How was the food?    The best laid schemes ... Gang oft agley ...
Reply:first use. lot of learning curve// hot spot caused one piece to turn black..need to rotate em around or learn to keep heat more even..food was real good....gonna do a shoulder or brisket next..
Reply:I like the fire box approach.  It is easy to load.  The flat top makes an excellent stove top surface..   But I only see a slight issue (of course I am arm chairing here):  if it had a clean out door, it would be easier to scoop out the coals and ash.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:i thought another door would just make for more air leaks...but there are three drain holes in the bottom for rain and ash..
Reply:Originally Posted by weldbeadfirst use. lot of learning curve// hot spot caused one piece to turn black..need to rotate em around or learn to keep heat more even..
Reply:Originally Posted by MoonRiseYour mailbox is on fire.    That's the first thought that came to mind when I saw the shape of the grill/food chamber.  It looks like a big mailbox.How was the food?
Reply:Whoa! Where is your location??? The way that meat is charred, I'm gonna question wether my wife was over at your house cookin you dinner!!!I like to hear a little moo when I cut into my dinner. But she is afraid for the kids and after all of her, just a little bit more's, that's what it looks like!"Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:Originally Posted by bassboy1 I don't think I've ever had to rotate food around in my reverse flow smoker, and it is large enough that we sometimes have 10 large boston butts in it.
Reply:You might want to turn the amps down a wee bit on those (ribs?)Were there any inclusions in the slag? Attached Images"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Moon it is not a mailbox obviously>  it has horseshoes on it, it could be a barn? Hey, I put horsehoes on every darned thing at the ranchita... and I love 'em... just kidding.  There's a lot of talk on meat, done etc.... but if U invinte these jokers over, they'll show up i betchaLincoln Power MIG 215Lincoln WeldPak 3200HDLincon ProCut 25Lincoln WeldanPower 225 AC/DCIf all else fails... buy more tools
GMT+8, 2025-12-24 16:42 , Processed in 0.130258 second(s), 18 queries .
