Hardfacing Vs Joining
发表于 2021-8-31 23:51:50 | 显示全部楼层 |阅读模式
Why it is not mettalurgically possible to use a hardfacing rod for joining purpose.Alternatively,which properties restric hardfacing rods for bieng used as joining rods.For example: - a straight chrome martensitic steel welding rod  ,normally used for cavititaion resitance is said to have tensile strength of upto 100kgf/mm2 and an elongation of upto 16% .and yet have a hardness upto 35 HRc ....hence our question is will such an alloy be alloyed to be used for joing purpose also..Please help with elaborate answersregardsSanjay
Reply:Here is and elaborate answer  :1. You can use hardfacing rod to join but....2. It is not made for penetration - it more lays on top,3. It is generally not ductile - it will break easily,4. Some hardfacing rods crack as they cool - a known issue,5. There are much better rods for joining - if you want a joint that is hardfaced just add a bead or two on top.You don't state the anticipated use so it is difficult to imagine the application.
Reply:NO.Don't do it.Whatever it is it won't last......zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:I would think that common sense says to use hard facing rod for hard facing.  Would you us diesel fuel in a turbIne engine that calls for using Jet-A? Sure you could do that, however the turbine engine will need an overhaul that much sooner. Use your 60xx, 70xx and 80xx to "join" metal. Use hard facing rod for hard facing.Lincoln Power Mig 216Lincoln AC/DC-225/125Miller  625 X-Treme PlasmaMiller 211 Forney 95FI-A 301HF 91110Victor Journeyman O/PMilwaukee DaytonMakita  Baileigh NRA Life Member
Reply:Thanks Everyone
Reply:Dissimilar compositions, brittle, plain and simple not the correct rod to use.Miller bobcat 225g  - spoolmatic 1Mm250 - 30a spoolMiller spectrum 375Thermal arc 95 Everlast Ex 250As the boiler turns, these are the days of our lives
Reply:Had a customer try and patch a 3/8" wall plating tank with hardfacing rods.     WHAT A STONE COLD PITA to grind out and fix right!!!!  what a damn nightmare!Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
GMT+8, 2025-12-24 16:42 , Processed in 0.190257 second(s), 18 queries .
