OT- CO2 tank for air tools
发表于 2021-8-31 23:51:45 | 显示全部楼层 |阅读模式
I have the tank but want to know if I can assemble this cheaper?I need a regulator so I can use lower psi for Air Tools"HyperFlo MAX 0-200psi Adjustable CO2 Regulator" 137.00http://www.wheelersoffroad.com/co2systems.htmI have an extra Welding Regulator that I can use - if possible-Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:I wouldn't see why not ,just need to adapt from reg output to npt for air fitting. Might need to add oil to replace cooling lube effect of condensed air from compressor(jk)ps this was going to be the next big thing a few years ago and fizzled, i liked the idea ,small high  psi tank ,go anywhere with tool no line dragging after you .Last edited by pennswoodsed; 05-09-2012 at 03:59 PM.Reason: more thoughts on subject
Reply:Thats how the pit crews do it  - lot of them us nitrogen instead of airThe main thing is not to panic or get excited Bobcat 250, X-Treme 12VS,  MM211Meltabo, Milwaukee,Porter Cable,Dewalt,MakitaVictor O/A, Ingersoll-RandEvolution Rage2, 40 amp PlasmaLincoln 225 AC/DC
Reply:I'm interested as well, what do you guys think of the cheaper $55 fixed 150 psi regulator?Lincoln 140 HD
Reply:I use the Western 200 psi fixed pressure reg. It's designed for that sort of thing.  I suggest large diameter hose for more expansion room even if your fittings are small. I love having CO2 and will continue to collect cylinders.http://weldingweb.com/vbb/showthread.php?t=114071
Reply:I know it is done- that is not question For Air tools you need a Regulator that adjust the pressure down to at least 90 psiToycoma- the Fixed one is fine as long as you only use it for Airing up tiresI wanna know if anyone knows where to source the pieces to make an Adjustable regulator-Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Ed,I'll stop by the LWS on the way back from work and see if they have any spare trade-in regulators. Probably won't be for CO2, but should work for your minimal needs. Quick stop in at the hydraulic supply should provide the fittings. See what I can come up with for you.EDIT: Just noticed you have a regulator already. Shot me the thread dimensions and I'll just pick up a fitting at the hydraulic supply house. Want standard pipe thread, male or female, for the quick coupling?Last edited by WyoRoy; 05-10-2012 at 01:25 PM.Lincoln PrecisionTig 275Miller 251Miller DialArc 250Bridgeport millHossfeld bender & diesLogan shaperJet 14 X 40 latheSouth Bend 9" 'C'Hypertherm 900Ellis 3000 band saw21"Royersford ExcelsiorTwo shops, still too many tools.
Reply:Thanks Roy-I tried to remove the Hose but it won't budge- I'll stop by my LWS and see what they can do for me.Lucky enough to have a cool LWS that will give me the timeEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:If they can't help you out right away Ed, just give me a shout. Gillette has better service and supply inventory for fittings than most areas due to the methane, mines, oil field, etc.EDIT: Also, if you want one of those fancy knurled knobs for your regulator, I can spin you one up on the lathe out of brass or aluminum.Last edited by WyoRoy; 05-10-2012 at 01:41 PM.Lincoln PrecisionTig 275Miller 251Miller DialArc 250Bridgeport millHossfeld bender & diesLogan shaperJet 14 X 40 latheSouth Bend 9" 'C'Hypertherm 900Ellis 3000 band saw21"Royersford ExcelsiorTwo shops, still too many tools.
Reply:As I said, give me a shout...fairly soon. Headed out on vacation in about a week and a half.Lincoln PrecisionTig 275Miller 251Miller DialArc 250Bridgeport millHossfeld bender & diesLogan shaperJet 14 X 40 latheSouth Bend 9" 'C'Hypertherm 900Ellis 3000 band saw21"Royersford ExcelsiorTwo shops, still too many tools.
Reply:For Air tools you need a Regulator that adjust the pressure down to at least 90 psi
GMT+8, 2025-12-24 16:52 , Processed in 0.094727 second(s), 18 queries .
