TIG visual aid
发表于 2021-8-31 23:51:42 | 显示全部楼层 |阅读模式
Hey, I'm pretty new to the site, but so far the knowledge of some of you guys just blows me away. So I figure we could get a thread going to capitalize on the expertise, and help the newer guys out. Soooo, I'd like to try it something like this:1-Post a picture of something YOU have TIG welded, whether it's good, bad, or ugly.2-Describe set-up: Machine, tungsten, cap, amperage, material, etc (in-depth as possible)-Now the hard part, hahah. Everyone gets to critique. Preferably only if you have experience and knowledge pretaining to the welded material. It would be best if you are as specific as possible, so that the less experienced guys can learn from the mistakes. I'll startLincoln Precision TIG 185 With foot pedal3/32 red tungsten, 304 Stainless Steel, 308L 1/16th filler, Max of 65 amps, # 6 cup with gas lensLast edited by Boomslang; 01-30-2009 at 08:26 PM.
Reply:(Click all images for lager view)Material: 6" Standard Wall PipeJoint Type: Single V-Groove (60 degree included angle)Backing: NoneRoot Opening: 5/32"Root Face: 1/16"Position: 5G FixedProgression: Upward ProgressionMachine: Lincoln Invertec V350-PROProcess: GTAW (TIG)Polarity: DCENAmperage:-Root: 110 Amps-Hot Pass: 130 Amps-Fill & Cap: 130 AmpsFiller: 1/8" ER70S-6Electrode: 3/32" EWTh-2Shielding: 100% Ar 15-20 CFHMore images and information available in original thread: 5G GTAW 6" Pipe ------------------------------------------------------------------------------------------------------------Material: 304L Stainless 1/4" thickProcess: GTAW (TIG)Amperage: 140-160 (I dropped the amps as the material warmed up)Electrode: 1/8" 2% ThoriatedShielding: 100% Argon ~15 CFH (used a gas lens)Filler: 1/8" 316L (all we had available)Machine: Miller Synchrowave 250dxMore images and information available in original thread: Some 1/4" Stainless Welds Visit Tensaiteki.com
Reply:http://weldingweb.com/vbb/showthread.php...ghlight=Intake...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:hi zap!
Reply:Originally Posted by weldbeadhi zap!
Reply:more where that came from..
Reply:ta 185  140 amps/pedal  3/32 lanth, 1/16th er70s2, overhead/horizontal, 1/4 ms Attached Images
Reply:ta 185 150 amps  with pedal, 3/32 red, 1/16 er70s2, flat, 3/8 ms stringer and weave over stringer.. Attached Images
Reply:Got a few, so just posting them as links: http://img144.imageshack.us/img144/4...00x1200qz5.jpghttp://img150.imageshack.us/img150/2...00x1200pl4.jpghttp://img89.imageshack.us/img89/968...00x1200om4.jpghttp://img502.imageshack.us/img502/4...00x1200ta3.jpghttp://img89.imageshack.us/img89/392...00x1200xb0.jpghttp://img141.imageshack.us/img141/6...00x1200yz8.jpghttp://img89.imageshack.us/img89/315...00x1200or6.jpgMaterial: 316L 5mm against 3mmJoint: T-joint and Square butt jointMachine: Kemppi MLS MasterTig 3003 AC/DCSettings: Pulse with 150-200A peak, 30-40% peak time, 1.5hz.Filler: 1.6 & 2.0mm (sorry, I'm euro)Shielding: Mison Ar
Reply:Originally Posted by BoomslangI'll startLincoln Precision TIG 185 With foot pedal3/32 red tungsten, 304 Stainless Steel, 308L 1/16th filler, Max of 65 amps, # 6 cup with gas lens
Reply:WoW! weldbead!!You have come a long way in short order...Must have a good teacher in your corner......zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:that i do.
Reply:Originally Posted by Tensaiteki(Click all images for lager view)Material: 6" Standard Wall PipeJoint Type: Single V-Groove (60 degree included angle)Backing: NoneRoot Opening: 5/32"Root Face: 1/16"Position: 5G FixedProgression: Upward ProgressionMachine: Lincoln Invertec V350-PROProcess: GTAW (TIG)Polarity: DCENAmperage:-Root: 110 Amps-Hot Pass: 130 Amps-Fill & Cap: 130 AmpsFiller: 1/8" ER70S-6Electrode: 3/32" EWTh-2Shielding: 100% Ar 15-20 CFHMore images and information available in original thread photo eliminated to speed up site.)------------------------------------------------------------------------------------------------------------Material: 304L Stainless 1/4" thickProcess: GTAW (TIG)Amperage: 140-160 (I dropped the amps as the material warmed up)Electrode: 1/8" 2% ThoriatedShielding: 100% Argon ~15 CFH (used a gas lens)Filler: 1/8" 316L (all we had available)Machine: Miller Synchrowave 250dxMore images and information available in original thread: Some 1/4" Stainless Welds
Reply:Originally Posted by SpeenHorizontal or vertical pos?
Reply:Originally Posted by zapsterhttp://weldingweb.com/vbb/showthread.php...ghlight=Intake...zap!
Reply:This picture, what are the rippling lines (look like scratches or an EKG) above & below the weld?  Is that where the cup was during the weld (walking the cup)?  I don't have or have ever done TIG welding, so I'm just curious.  If it's from the torch cup, were you walking the cup, or just moving the torch to manipulate the arc? Attached ImagesMarkI haven't always been a nurse........Craftsman 12"x36" LatheEnco G-30B MillHobart Handler 175Lincoln WeldandPower 225 AC/DC G-7 CV/CCAdd a Foot Pedal to a Harbor Freight Chicago Electric 165A DC TIG PapaLion's Gate Build
Reply:More study material..http://weldingweb.com/search.php?searchid=684926...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:^Nothing there???^ Do you use pulse on aluminum, or foot pulse it, or do you not at all?
Reply:Oops!Try this one..http://weldingweb.com/vbb/showthread.php...ght=gonkulator...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:fuel cell I did a while back, I thought i had better pics but this is the best I can findHave we all gone mad?
GMT+8, 2025-12-24 16:42 , Processed in 0.094761 second(s), 18 queries .
