6010 dcen=cutting torch
发表于 2021-8-31 23:51:40 | 显示全部楼层 |阅读模式
I found out today that running  1/8 inch 6010 rod DCEN at 120 amps  cuts almost as fast as a gas cutting torch. It makes a lot of noise also. I would say it cuts twice as fast as DCEPI was thinking of buying a plasma cutter, but I think this will work for most of the cutting I need to do. I am glad I found a use for these rods because I sure can't make a good looking weld with them.
Reply:Dip them in water before you use it to cut.  Works even better.
Reply:They call it 'hotrodding'.  The more amperage you use, the better it works.  Beware the smoke, as it'll scare the paints out of the safety guys if they're not expecting it.Benson's Mobile Welding - Dayton, OH metro area - AWS Certified Welding Inspector
Reply:Same with 6011"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Originally Posted by SupeDip them in water before you use it to cut.  Works even better.
Reply:Originally Posted by denrepFollow the melt with an air blow-gun, works even more better.
Reply:Originally Posted by denrepUse a carbon rod, works even more better yet.
Reply:I carbon arc with 6010 - 6011s
GMT+8, 2025-12-24 16:52 , Processed in 0.068309 second(s), 18 queries .
