questions on hobart handler??
发表于 2021-8-31 23:51:31 | 显示全部楼层 |阅读模式
anyone have one of these? the one i got was sitting for a while. im kinda new to the welding scene and it does ok but needs to be freshened up. what should i do to it??If the conversation isn’t money, then I’ll see you later.
Reply:I've got the Handler 210. which one do you have? I haven't had any issues with mine. Bought it new. but it should be ok to sit for even a year or two at a time as long as it's in a location where it's not sitting in water, or being invested by rodents.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Originally Posted by ThorsHammerI've got the Handler 210. which one do you have? I haven't had any issues with mine. Bought it new. but it should be ok to sit for even a year or two at a time as long as it's in a location where it's not sitting in water, or being invested by rodents.
Reply:well, is it 230v or 110V?There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Why don't you take a pic of it and show it here,MOE1?Drink a Guinness Draught....Millermatic 140Do you still rememberDecember's foggy freeze --when the ice thatclings on to your beard isscreaming agony.
Reply:i will upload a picture todayIf the conversation isn’t money, then I’ll see you later.
GMT+8, 2025-12-24 16:53 , Processed in 0.107191 second(s), 18 queries .
