Just looking around at the different types of tig torches there are after I have already ordered a WeldTec 20-25'R and just saw how CK's line uses brass inside the head instead of copper to reduce the abuse the thread see. I also took note of their water passage design that looks like it outflow the rest. I am confused though about the differences between their STANDARD series and their MASTER series,anyone have any ideas? their both the 20 water cooled torches that measure, weigh and have 250 amp ability............ whats the difference? I know that the master series torch is ~$10 more but what justifies that extra $10..... just not making sense.Also anyone ever use the *230*series rated for a whopping 300A? is the added amperage rating worth the added length/weight?like I said I have already ordered the weldtec torch but thought what the hell and just order a back up CK WorldWide body for "just in case" purposes.... lolthanks SQUARE WAVE 175 TIG DUAL MIG 151
Reply:Why is a guy with a 175A tig welder so concerned about a 300A torch.I'm sure a call to CK would put you in touch with someone who can explain (in great detail) the differences in their torches.Syncro 250 DX Dynasty 200 DXMM 251 w/30A SG XMT 304 w/714 Feeder & Optima PulserHH187Dialarc 250 AC/DCHypertherm PM 1250Smith, Harris, Victor O/ASmith and Thermco Gas MixersAccess to a full fab shop with CNC Plasma, Water Jet, etc.
Reply:Originally Posted by SundownIIIWhy is a guy with a 175A tig welder so concerned about a 300A torch.
Reply:I use a 150 amp CK Flexlock air/gas cooled tig torch on my 250 amp Idealarc welder.I have been very pleased with this torch's performance and longevity. Dont think I have ever welded at over 100 amps with it.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:If I need to tig weld something heavy enough to require more than 100 amps, I'd much prefer to stick weld it. cheaper and faster with stick.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:Everything was fine with the torch that came with the welder (LA-9 magnum) till I started to weld Aluminum, didn't take long for the torch to get hot and rubber was steaming so I figured I should upgrade it to a water cooled. The 9 series torches look to be rated @ 150 amps and the machine does 175 so pushing the limits with the Aluminum welding I believe. I ordered the CK 230 that I mentioned and have a Bernard 3500ss water cooler on the way as well, I know it's overkill bit couldn't beat the price. I almost was gonna build one but after compiling the cost of building a "proper" cooler, it was cheaper to buy the used Bernard. SQUARE WAVE 175 TIG DUAL MIG 151
Reply:I called CK Worldwide to see what they had to say about the difference between the standard series and their Master but all their Tec's were buisy so I sent an email and this is what I gotThanks for the interest in our TIG Torches!The Standard TIG Torch line is made up of the Original Linde design whereas the Master TIG line is made up of Original Linde designs with added CK features, put simply.In the case of the CK20 vs. the CK200, torch heads (bodies) are the same. However, ordered as a 12.5ft or 25' Torch package, the #CK20-25 has three separate hoses whereas the #CK225 has bonded tri-flex hoses that are glued together to minimize tangles.In the case of the CK230, this Torch is proprietary hence it certainly falls under the Master TIG label. The power cable is larger (10 ga.) @ 300A @100% duty vs. 250A @100% duty (12 ga). The handle is larger to accommodate the larger power cable so the handle isn't interchangeable with the CK20/CK200.All Linde Style CK TIG Torches use interchangeable Linde style front end consumables. *In the case of the CK20/CK200/CK230, these are named "2 series" consumables. *I've attached a handy Parts Poster for your use.I hope this helps?http://www.ckworldwide.com/CK200F.pdfhttp://www.ckworldwide.com/CK230F.pdfKind Regards,Sjon DelmoreSjon Delmore CWI/CWENorth American Sales ManagerCK Worldwide, Inc.3501 "C" St. N.E.Auburn, WA. 98002www.ckworldwide.com800-426-0877253-350-4241 [email protected] SQUARE WAVE 175 TIG DUAL MIG 151
Reply:Apparently he's never been to their site because it says you can get both Master or standard series torches with the superflex cables or standard (I'm assuming standard is "triflex") cables. lol, also he said that the 20 (standard) and 200 (master) torch bodies are the same thing but the prices are different? SQUARE WAVE 175 TIG DUAL MIG 151 |
