submerged arc/engine driven
发表于 2021-8-31 23:51:29 | 显示全部楼层 |阅读模式
Hi,My question is: Have you ever seen a submerged arc welding machine operated with a diesel welding machine(engine-driven)?I have an amperage range of + or - 450 amp with thread 3/32 on steel.Thanks for your answer
Reply:Yes................pretty common6 Miller Big Blue 600 Air Paks2 Miller 400D6 Lincoln LN-25's4 Miller Xtreme 12VS2 Miller Dimension 812 4 Climax BW-3000Z bore welders Hypertherm 65 and 85Bug-O Track BugPair of Welpers
Reply:OH PAVENSTEELMAN!!!!!!!!!!!!!!!!!!  Your expertise is required.Lincoln 300 Vantage 2008300 Commander 1999SA250 1999SA200 1968Miller Syncrowave 200XMT350MPA/S-52E/xr-15Xtreme 12vs Millermatic 251 w/30A  Millermatic 251 Dialarc 250 Hypertherm 1250 GEKA & Bantom Ironwokers
Reply:No problem need 400 plus amps 500/650 amps better ,  will work cv/cc any feeder 5/64" wire ,3/32 & .045  L-50, L-56 , L61 & L75 wires are mig or sub arc . For a gun yes Lincoln or Pro Fax they have a flux cone gun that will work with any feeder . That DC-650 is the cats meow for heavy work .
Reply:Typ FCWP  LA-75 5/64 860 flux 385 amps +37-0 amps  29 +2-0 volts DC + 11ipm travel Attached Images
Reply:That thin sheet metal welding is so cool! Keep posting pics at any excuse to do so.
Reply:Originally Posted by PavinsteelmanTyp FCWP  LA-75 5/64 860 flux 385 amps +37-0 amps  29 +2-0 volts DC + 11ipm travel
Reply:Is sub arc a prequalified procedure or would a PQR have to be set up to be D1.8 compliant?Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
GMT+8, 2025-12-24 21:33 , Processed in 0.102064 second(s), 18 queries .
